how to get 300hp withn speed density
  • Thread starter Thread starter stangguy87
  • Start date Start date Feb 19, 2007
stangguy87
  • Feb 19, 2007
does anyone know how to get over 300hp w/speeddensity injection, other than converting to mass air?
302fordracer
738
Vancouver, WA
Feb 19, 2007
  • Feb 19, 2007
if it is even possible I would say I highly do not suggest the attempt...switching to MAF isn't very expensive, and there was a good reason ford did it...When you mod a speed density car it changes the amount of air coming into the engine at every rpm and the computer relies on set value of air density to know how much fuel to add...modding a speed density car can cause it to run like total crap man...I was only putting down 244/292 at the wheels right after my swap to MAF and right before the swap with all the same parts...the car stumbled and jerked around while accelerating...the computer just didn't know how much fuel the engine needed...
poneypower89
Now everyone in the world will know I wanna bang t
Dec 6, 2004
Indianapolis, Indiana
Feb 19, 2007
  • Feb 19, 2007
didnt boosted joe lay down over 300hp on the dyno with his speed density car and a supercharger
Of course, I would NOT ATTEMPT ANYTHING that man did...
unless you like lots of problems and wheels flying off... that sorta stuff.
302fordracer
738
Vancouver, WA
Feb 19, 2007
  • Feb 19, 2007
I am not saying it isn't possible...I just thought I should share my experience and warn that you may have trouble attempting such a thing..I am sure it could be done with a chip and a tune to tell the computer the updated air density numbers...I am just saying it isn't all that expensive or difficult to do, to switch to MAF...and the benefits are great...there as I said is a good reason why ford did the upgrade...
2000xp8
SN Certified Technician
Aug 8, 2003
8,063
1,647
194
NJ
Feb 19, 2007
  • Feb 19, 2007
This is a good SD site, there is a list of all the SD friendly cams too.
http://www.50tech.com
brian15
81
  • Feb 19, 2007
good aftermarket heads
a crower 15511 cam or equal
performer rpm intake or similar ....
300hp there ya go ....with supporting goodies
carbed87
215
  • Feb 19, 2007
dagz was telling me it's possible to run SD with a kenne bell setup. now im sure this is the case for every sc, but we were talking kb and thats what he told me.
Modular2v
3,222
23
99
oklahoma
Feb 19, 2007
  • Feb 19, 2007
speed density also likes nitrous!
Mustang5L5
Mod Dude
Feb 18, 2001
43,347
18,082
224
Massachusetts
Feb 19, 2007
  • Feb 19, 2007
I don't see what the big deal is. I'm still running speed density even though i've had a mass air conversion now for over 4 years. I just don't feel there is a need to yet. You can still do all the other mods and there are even SD-friendly cams.
So a good set of heads, intake, tb and all the supporting bolt ons can still take you over 300HP.
795.0pacecar
lover of pudgy polygamists
Jul 11, 2003
480
Senoia, GA
Feb 19, 2007
#10
  • Feb 19, 2007
  • #10
I was making 260 rwhp with speed density and the car ran fine, it didn't like to idle very well, but other than that it ran like a raped ape. I converted to mass air to improve my idle quality, but I think I also gained some power throughout the powerband with mass air.
90mustangGT
I felt sorry for girls because
2,773
17
89
Dallas, GA
Feb 19, 2007
#11
  • Feb 19, 2007
  • #11
The pro's of a MAF system is it helps "adapt" by adjusting fuel/spark according to how much air it measures going into th engine. Speed/density takes engine speed, along with the MAP reading, and adjusts fuel from there. The TPS "prepares" in both system and the final adjustments are done through the 02 sensors. If you reduce vacuum, or anything on a speed density system, it will not run right.
A con of the MAF is that vacuum leaks, turbulance, and a host of other factors can influence the readings. Many vehicles do not have MAF sensors, and do just fine without them. If you had an aftermarket computer, you could get rid of one or more sensors. I know people who run no O2's (because they run a lot of race gas) and those who run no MAF as well, they have thier car's dynotuned though and there are some setbacks, such as it has many of the same characteristics as a carbed car, but for the most part, it makes things more simple.
troyGT03
278
too close to memphis,tn
Feb 19, 2007
#12
  • Feb 19, 2007
  • #12
more than that can be done with sd. my current setup on my saleen is a fresh 306 with gt-40 aluminum heads and gt-40 intake with a novi 1000 pulleyed for 6lbs. 300hp is no problem. i havent put it on the dyno yet but the 300 mark is way low for my combo... i will post some new pics later
25thmustang
Mustang Master
Sep 5, 2003
2,021
85
99
Montgomery, NY
Feb 19, 2007
#13
  • Feb 19, 2007
  • #13
My brothers 86 right now is SD, and with my dads GT40P motor it put down 292 to the wheels before. It is the same motor and was running fine. We have since switched to 19 lb injectors (for emissions) so it is probably in the high 280 range for power!
troyGT03
278
Feb 19, 2007
#14
  • Feb 19, 2007
  • #14
yes sd loves nitrous. i had many sd cars with nitrous. my setup was kind of a project for me to see how far i could go with sd. does it run like a raped ape...absoutely. driveability problems...none. would it make more hp with a maf conversion...sure. i am at the limit of sd and have to upgrade. it runs awesome and i have no problems.
Roland69
Sergeant Tangnet
Sep 17, 2005
2,867
Port Elgin, Ontario
Feb 19, 2007
#15
  • Feb 19, 2007
  • #15
I would like to leave mine S/D and make good power just to say I am still S/D
302fordracer
738
Vancouver, WA
Feb 19, 2007
#16
  • Feb 19, 2007
  • #16
All you people had success with this eh? I wonder what can be different about my car...maybe it was the e-cam? I don't quite know...all I can say is mine lacked power and stumbled all over the place with my mods and speed density...threw a MAF sensor on there and all was well...
795.0pacecar
Jul 11, 2003
480
Senoia, GA
Feb 19, 2007
#17
  • Feb 19, 2007
  • #17
I would have to agree that it was your E-cam that caused most if not all of your problems..
D
Daggar
3,902
#18
  • Feb 20, 2007
  • #18
It is MORE than possible to run 300 HP with SD. If there weren't such a lack of support for the Ford SD computers and the expense of running an aftermarket SD computer, I'd STILL be running SD.
My old engine combo (stock 86 upper and lower end) ran 317 ft/lbs and 375 tq (roughly) at the wheels with a 2.2L KB and 9 lbs of boost.
There are still a few places that have the software/hardware to electronically tune Ford SD comuters but they're getting harder and harder to find.
I imagine that a custom grind SD friendly cam and a good set of heads with my KB could have put me well into block splitting territory. Alas... I went with a DART block and lots of goodies so a MAF conversion was the best bang-for-the-buck option under those circumstances.
I've always wanted to do a high compression SD friendly and streetable setup for an 85 or 86. One day, when I have nothing but time and money......
P
Phatt_daddy
219
Hytop, AL
Feb 20, 2007
#19
  • Feb 20, 2007
  • #19
Finally some ppl that are saying what I am..... Hating to hijack but i GOT ONE QUESTION..... will a f cam work on a stock sd setup? All that has been done to my engine is a forged bottom end or at least that is how I bought it with the f cam in it.
Thanks
Nate
troyGT03
278
Feb 20, 2007
#20
  • Feb 20, 2007
  • #20
Thanks
Nate
survey says.......noooooo.....please try a sd friendly cam. all of the fms cams have too much lift/duration for sd. it will run but idle and driveability probs will be huge.
Y
Speed density 302 to carb 351W
  • yaboity
  • May 29, 2026
  • Fox Engine Swaparoo
Fox Engine Swaparoo May 29, 2026
AeroCoupe
How to convert Speed Density to Mass air - Complete walk thru!
  • TTSaleen
  • Sep 22, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 22, 2025
TTSaleen
Requesting Guidance for 306 motor swap - Fuel? - SD? MAF?
  • So_Flo
  • Jul 26, 2025
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jan 4, 2026
Mcmahst
D
96 get convertible-sell or part out?
  • DTCstang
  • May 17, 2026
  • What is it Worth?!?!?
What is it Worth?!?!? May 18, 2026
nickyb
Exhaust Exhaust resonance
  • keel
  • Jul 24, 2026
Fox 5.0 Mustang Tech Aug 11, 2026
keel
