Remove the door skid plate (Plastic strip that is right besides the seat) 4 screws usually hold it in. Undo the push clip that holds the plastic kick panel, then move some of the wiring out of your way. You need to use a 10mm socket on the large connector that goes to the computer to unbolt the wiring, then remove the small grounding screw that holds the whitle plastic bracket that holds the coputer up, I think it is a 8mm. The computer will come straight down then out...
