The condenser sits in front of the radiator, so both the fan and radiator will have to come out. The condenser should also come with 2 rubber brackets for mounting. It has 2 posts that go into the bottom two holes designated for them, and the two rubber brackets are used to mount the radiator to the frame. It's very simple.
All the A/C lines are hardlines, and should be very self explanitory because they are already "pre-bent." I'd need to see a picture of the parts you are having trouble identifing in order to tell you exactly where they go.
Good luck.
Joe
