the switch will just make sure your at WOT, as you want to be when spraying.
a window switch will make you spray at a set rpm "window" or range of rpm, this is important as you want to start spraying at around 3,000 rpms (more imp. with a wet kit so you dont get fuel drop off, or fuel that will fall out of the n2o mist and puddle) or so and prob. stop when your combo is at its peak power making rpm or just a hair over. This makes the WOT switch or micro switch imp. as you can rev. to 3,000rpms without being at WOT.
so you should run both for all around safty of system.
