  • 1994 - 1995 Specific Tech
how to lower?
  • Thread starter Thread starter Mustangless
  • Start date Start date Sep 11, 2005
Mustangless
903
home
Sep 11, 2005
  • Sep 11, 2005
I was thinking about just getting the eibach pro-kit but thought it might be a little rough. I know nothing about suspension so some of what I say might be dumb. If I buy THIS is there any advantages of this vs the pro-kit? Will I need to buy anything else to go with this stuff? Is there anything else better? I want it lowered about the same as the prokit would do.
Would the pro-kit make the 1/4 time slower?
blk9450
1,507
your moms bed
Sep 11, 2005
  • Sep 11, 2005
those are just shocks
see at the bottom where it says works with stock or lowering springs
i love my prokit
bubba-dough
1,044
Indiana
Sep 11, 2005
  • Sep 11, 2005
Yep, it says set of 4 - 2 struts 2 shocks. I had the Eibach on my 96 (which I no longer have) anyway the ride was great and the stance was awesome.
I would also recommend changing your struts and shocks at the same time if they are old.
pgpony
Pine Grove, PA
Sep 11, 2005
  • Sep 11, 2005
If money isn't an issue, I would think that the Tokico setup would be the way to go. I have never gone with a coil over setup like this, but everyone that does seems to really like it. Tokico is a great name. My brother-in-law has the 5-Way Adjustables on his Fox-Body and loves them.
blk9450
1,507
your moms bed
Sep 11, 2005
  • Sep 11, 2005
thats not a coil over setup. it says it works with stock or lowering springs. stock isnt coilover, so these are not coil overs.
juiced_94gt
1,143
Southern California
Sep 11, 2005
  • Sep 11, 2005
I just replaced my front pro-kit with some coilovers for my bilsteins and i must say that it was a HUGE improvement over it. But the pro-kit did feel good with the bilsteins.
Mustangless
903
home
Sep 11, 2005
  • Sep 11, 2005
that sounds nice to do but sounds to expenisve. How bad will the ride be with stock shocks and the prokit?
also does anyone have a pic with the prokit?
tomustang
Psychotic Member
3,434
McLean Hospital
Sep 11, 2005
  • Sep 11, 2005
Atleast the pro-kit is a progressive type spring. the coils will independently get stiffer insted of the entire spring so it will give a smoother ride and that extra little drop.
HoofnIt
1,175
North Carolina
Sep 12, 2005
  • Sep 12, 2005
I installed the prokit this past spring and although the ride is somewhat 'rough' compared to stock the improved stance is well worth it. I'm running 18s & stock shocks/strus-I'm saving for the Bilsteins.
Mustangless
903
home
Sep 12, 2005
#10
  • Sep 12, 2005
  • #10
is there anywhere where I can order a complete coilover kit that includes everything I need? I am thinking coilover is going to cost too much
edit:
If I go with the eibach pro-kit will I need to order anything else like the caster camber plates?
blk9450
1,507
your moms bed
Sep 12, 2005
#11
  • Sep 12, 2005
  • #11
try doing a search for coilover kits.
anythime you lower more than about an inch you should used c/c plates, i havent got them yet but i dont see any abnormal tire wear
Suspension Harsh Ride
  • PonyGTrider
  • Mar 20, 2026
  • 2 3 4
2K
Fox 5.0 Mustang Tech Apr 11, 2026
W
Speedometer and shifting issues
  • wyatt-tetro891
  • Aug 17, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 18, 2026
wyatt-tetro891
W
What's it Worth? 2000 GT
  • Mustang5L5
  • May 8, 2026
  • What is it Worth?!?!?
What is it Worth?!?!? Jun 13, 2026
KRUISR
D
Will 2023 (Non-Handling Pack) Mach 1 Wheels Fit A 2013 Mustang GT OK?
  • dmw_4814
  • Oct 27, 2026
  • 2010 - 2014 Specific Tech
2010 - 2014 Specific Tech Oct 27, 2026
dmw_4814
D
Progress Thread Progress Thread- From6to8's 95 GT/Saleen Supercharged 331 install
  • from6to8
  • Mar 22, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 28, 2026
from6to8
