How to make computer think the EGR is still there?
moneypit94
1,723
Macomb, IL
I know i have seen threads on this but EGR is too small of a word to look up...
Anyways I need to know how you guys without a chip got your check engine light to come off without having an active EGR?
So far this is the only downside to my new pms system...
stangbanger94 said:
unscrew the white piece on the back of egr valve off, with conector still attached. Tape the prong so that it's pressed in, and that should give the computer a good egr signal, without the valve present.
I taped it all the way down and the cel still came on... Maybe it is half way like mytight said? I will check it out later... Either that or its coming on for some other reason?
Anybody else do this?
It is 1/2 way. I did that and no C/E light until the heat from the engine melted the tape and came loose :notnice: did that a few times so I said screw it... I'll deal with the C/E light
Pushing it in half-way, worked like a champ... Thanks guys...
BTW i think this week im going to cut that needle in half and find a way to screw a plate down flush... If it turns out good i will let you all know...
I think Andy rigged up something kinda like that... Drilled a hole in a rod that held the plunger down 1/2 way. Not sure if it was him, but remember reading about it a long time ago.
thats not a half bad idea... cut the pluger really short, then drill like a pilot hole perpendicular with the plunger and then while holding it down with something put a screw or pin in of some sort...
I saw a thread where there is already a screw hole in the side. By putting a tiny screw in it, his stopped. Mine did not have one so I took High Temp RTV and covered it really good. So far, not a problem.
Paul
i took a piece of stock alum. and mic'd the length of the plunger rod, and then drilled the hole in the alum. half of that in depth, i then took some self tapping screws and put three through the holes in the sensor into the alum. never had another prob. with it coming loose or anything :cool:
p.s. i tried taping it and it eventually fails, and that &$*% light drives me nuts
jason
what effects does it have to the tune of part throttle?
also what effects do long tubes have on the part throttle and WOT tune?
I wouldnt want to do the 2 and have it go too lean at part.
