stupid kids!gospeedgo said:It must be a guy thing![]()
That would be correct. Acetylene is what we call an oxyfuel. It is NOT an inert gas. I get to use it almost every day at work with an oxy-fuel torch or a trackburner which is a torch on wheels to get the most perfectly straight cut. Think propane. Propane can also be used for cutting and is more commonly used for it being a bit cheaper. When the proper amount of oxygen is applied, the propane will burn at 5300 degrees, acetylene is hotter at 5800 degrees and gets to the cut quicker, I really can't differentiate the difference in the quality of the cut between the two but the acetylene saves time.WaterPog said:um...I think you are confusing Acetylene with Acetone, very different stuff.
Acetylene is the fuel used for welders, it is a gas at normal pressures and temperatures and very very flamable/explosive even with just ambiant oxygen levels. Acetone is primarily used as a solvent, and is a liquid at normal temps/pressures. It's also flamable but nothing like acetylene.
Haha! I am SOOOO hooked on Family guy. Nobody understands.
