I just installed a new high volume Melling oil pump and am now trying to prime it. I prefilled the oil pump outlet with some oil before bolting it up. I'm running a drill with a priming tool through the distributor hole and as far as I can tell, it's turning the pump (ccw). But, a mechanical oil pressure gauge isn't showing any reading after a few minutes worth of spinning in 15-20 second runs. I have good oil level, no other changes to the previously running engine.
How long should I expect to keep this going? It's gotta be picking something up. What else can I try?
Bonus points: I'm new to SBF's, so if you can recommend a good book that can help me with engine procedures like this I'm open to suggestions. e.g. rebuilds, common service points, etc. Just don't say Haynes or Chilton.
As a result, I was never turning the pump. The resistance I felt was the priming tool rubbing around whatever was in its path.
