How to put a speedo in
speedo gear right? loosten the 1 bolt holding the speedo housing on transmission where the speedometer cable enters the tranny on drivers side mid way of tranny. pull housing out and pull the speedo gear off the end of the housing and push the new speedo gear on where the old one was removed and reinsert housing where it was removed and tighten bolt and your done...
Don't forget to pull the second clip out. The first clip is metal and holds the cable into the transmission. The second clip is plastic or metal (not sure) but it holds the gear in. Remove the second clip and then pull the gear. Don't forget to put the second clip back in when reattaching the cable to the transmission.
Here's how to do the speedo cable. You do many of the same things to replace the speedo head.
Speedometer cable replacement for 87-93 Mustangs.
Note: All 89-93 cars have a VSS sensor even if they do not have cruse control. The 87-88 only have a VSS sensor if the have cruse control.
Speedo cable housing assembly without cruse control:
Speedo cable housing assembly with cruse control
Inside the car:
1.) Remove the shield around the steering column that covers the ignition switch & turn indicator switch.
2.) You now have access to the two screws that hold the lower part of the cluster housing in place. Remove them and place them in a zip bag.
3.) Use a stubby or an offset Philips screwdriver to remove the two screws on the top of the cluster housing. The screws are up close to the windshield, so they can be hard to get at.
4.) The cluster housing will now slide forward: depending on your particular car, you may or may not have to disconnect the wiring for the headlights, hazard lights, or cluster wiring. All of the wiring uses plastic connectors with plastic spring clips on them. To release the connectors, lift the plastic clips and pull straight back.
5.) The speedo cable is secured in the speedo head by a white plastic clip. Depress the clip or squeeze it and pull the cable out of the speedo head. This can be tricky, but it will come out if you have the white clip depressed enough.
Outside the car, replacing the cable housing assembly. The following steps are necessary only if you plan on replacing the cable & cable housing assembly.
6.) If you are going to the replace the cable housing, the next step is important. Tie a study string or wire to the VSS sensor end of the cable housing. This string or wire is to be used to fish the cable housing back through the maze of wires that is under the dash. If all you are going to do is replace the inner cable, you can omit this step.
7.) Jack up the car, all 4 tires must be off the ground. Place jackstands under the car for safety.
8.) Locate the VSS sensor on the driver’s side of the transmission tailshaft housing. The speedo cable housing will be secured in the VSS sensor with a hairpin clip Do not remove the clip!!!: The hairpin clip stays in place. If you remove it, the odds are that you will not be able to get the cable to stay in place on re-installation. Pull firmly straight back on the cable housing and it will come out. A considerable amount of effort may be required to get the cable out of the VSS sensor, but it will pull out.
9.) Release the cable housing from the clips that secure it to the car body.
Inside the car:
10.) The housing assembly can then be pulled out and the fish string or wire can be removed from the old cable housing and secured to the new one.
11.) The inner cable can be removed by pulling it out of the housing assembly. Watch out for the lubricant so that you don’t get it on the car’s interior.
12.) Lubricate only the lower part of the new cable with speedometer lubricant or graphite. Don’t use too much lubricant, or it will work its way up into the speedo head unit and damage it. Thread the inner cable into the housing, turning it as you go. When you are all the way in with the new cable, it will engage the VSS sensor and stop turning.
13.) Use the fish string or wire to feed the cable housing assembly through the dash wiring and out the cable hole in the firewall.
14.) Secure the cable in the body clips, making sure that the cable isn’t rubbing against the exhaust pipe.
15.) Push the cable housing assembly into the VSS sensor until it snaps in past the hairpin clip.
Inside the car:
16.) Push the cable housing back into the speedo head unit. You should be able to feel the white clip click into place.
17.) Reconnect all the wires & connectors on the speedo head unit.
18.) Re-install the cluster unit in the dash & tighten the 4 screws that hold it in place.
19.) Re-install the cover for the ignition switch & turn signal.
20.) If the car is up on jackstands, start the car, place it in gear & watch the speedo to see if it works OK. If you didn’t jack the car up, take a test drive.
