How to remove/block egr.
  • Thread starter Thread starter 91Cpstang
  • Start date Start date Jun 18, 2005
9
91Cpstang
  • Jun 18, 2005
I am building a 10:1 306 w/ GT-40 alum. heads. How do I block the egr w/o causing drivability issues? I have the Trick Flow .499/.510 cam. Is it worth the trouble to remove it, or is there a performance increase by doing it?
Thanks, Herc
srothfuss
Last night I stabbed the same guy 7 times in a row
Oct 17, 2004
1,796
Woodward Ave.
Jun 18, 2005
  • Jun 18, 2005
There is zero gain by removing the pump / EGR system. The system only operates when you are cruising down the highway. EGR turns itself off at WOT.
If you do remove it, make sure you turn off the function in the ECU.
88 Fox GT
1,674
Iowa
Jun 18, 2005
  • Jun 18, 2005
Keep it. The EGR increases fuel mileage when cruising down the highway.
giddyup306
3,041
Jun 18, 2005
  • Jun 18, 2005
ditto
txstang84
1,639
42
69
Tuscola, tx
Jun 18, 2005
  • Jun 18, 2005
the only downside being the sooty garbage that will make a home in your runners over time...
Hello Everyone !
  • 5150K
  • Jul 3, 2026
  • The Welcome Wagon
The Welcome Wagon Jul 3, 2026
5150K
H
Ongoing Battle With Hydraulic Lifters
  • hailer06
  • Jun 8, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 9, 2026
  • Locked
Engine Might have to get a Dart block but don't want to and if I do, then 363 instead of 331. Thoughts on what I've already bought so far.......
  • from6to8
  • Jul 8, 2025
Fox 5.0 Mustang Tech Jul 8, 2025
  • Gulftown980x
  • Jul 29, 2026
  • SN95 4.6L Mustang Tech
squeak93
Engine 1990 LX 5.0L EFI Mustang Fuel Management Problems - HELP!
  • 5.0LXStanger
  • May 25, 2025
  • 2 3
3K
Fox 5.0 Mustang Tech Jul 11, 2025
5.0LXStanger
