How To Remove 'Cart Bumper' Door Trim?
dental floss and water, windex,(whatever wont hurt your paint) as a lube for the floss. Then use adhesive remover to remove the glue redue(rub with a little muscle but not hard). Then apply a coat of cleaner wax when finished.
sgarlic said:
Although I have no clue what you're talking about (even walked outside and stared at my doors for a few minutes to try,) here's a bump for you.
It's very rarely put on GT's, but i have seen it on a few.
WHat he is talking about is usually put on V6 Mustangs. It's been put on them since 1994 and dealers still put them on '06 V6 Mustangs
He means these things smack dab in the middle of the door
vld said:
yep. thats what i am talking about. i have no idea why they ended up on my doors but they must go. thanks for the instruction squares98.
I removed them on mine last spring. I used a hairdryer at about 6 inch from the molding and gently pull it off the body. I mean very gently. It will come off without damage.
Cleaned the residu off the doors and let it be for 24 hours. You ll see after the removal some mark on the paint. It will disapaer after a while ( 24 hours ) than wax it.
