How to remove ford 9" axles?
  • Thread starter Thread starter Rmoore45
  • Start date Start date Jul 1, 2011
R
Rmoore45
142
Jul 1, 2011
  • Jul 1, 2011
How?? I have the bearing retainer removed, but the axles wont budge. I tried using the brake drum as a slide hammer, but to no avail . Is there something that I'm forgetting? Or maybe a special trick to get them to come off?
Thanks, Ranger
Realmongo
I prefer to be called "Evil Genius"
2,466
86
99
Western Mass
Jul 1, 2011
  • Jul 1, 2011
After you remove the 4 bearing retainer fasterners, all you do is use a slide hammer to pull them out. Some of them can be a BEAR after being in there for so long!
iskwezm
4,159
20
79
Rowland Heights,California
Jul 1, 2011
  • Jul 1, 2011
a slide hammer will give more of a impact to break them loose.I used a drum the first time then i had to buy a slide hammer
robbz28
775
Epps, LA
Jul 1, 2011
  • Jul 1, 2011
A slide hammer would definately work, but if you dont have one, a few raps on the hub with a rubber mallet will probably loosen it up, or you can use a regular hammer if you have a block of wood or something to put between the hub and the hammer...don't hit it directly withva metal hammer.
R
Rmoore45
142
Jul 3, 2011
  • Jul 3, 2011
I borrowed a slide hammer from O'reillys, worked great.
Thanks for the advice
J
2004 Mustang 3.8L V6 vibrations above 65 MPH and differential leaks
  • joeybuddy96
  • Mar 16, 2026
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Aug 29, 2026
joeybuddy96
J
F
Ford 460 swap
  • Ford460
  • Sep 13, 2026
Ford460
F
Rear diff noise, hard to turn axle and driveshaft
  • DeathProof88
  • May 23, 2024
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- May 24, 2024
General karthief
Eight inches is enough for me...
  • 351MooseStang
  • Nov 27, 2025
1974 - 1978 Mustang II Talk & Tech Mar 2, 2026
Bullitt347
  • B0udreaux
  • Jul 14, 2026
AeroCoupe
