How to remove stock air filter
Well, still stuck here.
The plastic is too hard to just move aside.
So what needs to be removed?
Which band has to be removed or both (arrows to in red and blue)?
Do I unplug the two sensors (arrows to in yellow)?
Thanks
Remove the band clamp connecting the plastic tubing to the throttle body.
Yes, unplug both the MAF and IAT harnesses, unplug the short little s-shaped hose going into valve cover by signature plate, and remove the lone bolt holding the air filter box to the fenderwell (IIRC, 10mm?).
I think that's it...
