How to run fuel pump on 2000GT without starting it?
04sleeper
2,674
14
89
Dallas, TX
Is there a way to run the fuel pump on a 2000 GT by jumping a relay or something so that you can drain the tank without having to start the car?
A friend of mine in FL would like to get some fuel for his generator out of his car without siphoning it. He is stuck without power from the hurricane so he can't even get online to ask. :Damnit:
Any help would be appreciated. :cheers:
Thanks.
Kevin
Thanks guys.
He tried to siphon it with a pump and it did not work.crapola
Then he tried to just key it over and it did not work either.....:bang:
The reason I ask is because I have done this several times on a fox body by jumping the relay under the seat to empty the tank to install a fuel pump.
Thanks.
Kevin
Yes, you can.
Under the rear bumper unplug the fuel pump harness. Use a 12 volt source and put the wires in the plug that goes to pump. There are 6 places just find the right one really easy. I've done a few times on my 02 GT.
y2k02 said:
Yes, you can.
Thanks there y2k02.:nice:
I will have him give it a try.
