I am looking for the best way to seal internal leak on my 302. This is my 3rd try (and will be 3rd oil change while driving 0 miles), yet coolant has always found its way to the oil pan (I can smell coolant in it). This leak must have gone through either timing cover/block passage, or through intake manifol&head passage (or elsewhere assuming head+block has no cracks?)
I am thinking about using permatex instead of pre-cut gasket for the timing cover. Do you think it is OK to use grey permatex without gasket? I understand this RTV is stronger than regular blue RTV (fails at 340 psi vs. 230 psi).
