I've tried to achieve that goal, seems to have worked pretty well. I went with the following:
UPR Tubular K Member & A-Arms ......for obvious reason
QA1 Drag Race Coil Over Springs ......#140 rate
KYB AGX Adjustable Struts ........fully adjustable from darg to sport
Caster Camber Plates .............obvious again..
Stock Sway Bar, Poly Mounts ......gota have a sway bar to corner..
245-45-17 BFG KDY
8 pt roll cage with subframes
Rear:
UPR Pro Series Rear Suspension Kit
UPR Adjustable Solid Upper and Lower Control Arms ..tight for corners and hard for launches
UPR Anti Roll Bar .. Minimizes body roll in the corners and launches straight for drag racing.
UPR Tourqe Box Reinforcments ...duh
Stock Springs ...satisified
Stange Adjustable Shocks ..once again youll need adjustable shocks
274-40-17 BFG Comp T/A Drag Radials..and drag radails for obvious reason...The car hadles realllly tight around corners, doesnt feel like a boat, and is equiped with a full drag suspension.
You have to find that happy median, meet halfway. Your going to need adjustables, so when u bring it to the trip, ur loosen up the front for launches and tighten up the rear end..
