How to tell if your car is running lean?
stangGT97
1,299
Boston area, MA
Well, I just installed my MAC CAI and rotated the MAF according to the darkwolf mod... I definitely noticed a SOTP power gain, but now when i downshift something feels off... like it will be slowing down smoothly, but then the exhaust will pop and the car will jerk slightly. Does this mean my car is running lean, or is that just something that happens with increased airflow in and out of the engine (i have a high flow X pipe). I know the engine doesnt ping at high rpms too... thanks for any help!
pull one of the plugs (from each side of the motor). you can get alot of info just from looking at yur plugs. if the center of the plug looks too white, youll know yur running lean. other than that pull voltage coming from the 02s to the ECU. or get an air/fuel ratio meter.
the only way you can know for sure is too get it dyno tuned. reading the plugs can help if you know how too. but i would'nt bother with a air/fuel meter. unless it's a wideband one it's usless..
I have the A/F guage in my car and I can tell you that about 4-5 seconds after i LET OFF THE GAS THE ENGINE DOES WHAT IS CALLED A "FORCE LEAN" CONDITION (sorry bumped the caps). It is to save gas. Mine makes a little buck when i happens too. The only reason I have the A/F guage (not wideband) is that under nitrous, you should always have it in the rich. At WOT mine pegs rich. That is good right?
What is the darkwolf mod and what are the benefits.
Rotating the MAF do to the elbow of the CAI that puts the air filter in the fender.
I've tried it,gave me issues,check engine light after a few weeks,even went to a dealer that i deal with,and we were moving the MAF side to side,and saw how touchy it was on the readings while being plugged into the ford dianostics computer.I personnally think the hole CAI thing ,and darkwolf thing is ... :notnice: .Sorry had too. :D
Believe in what you want to believe.Ford positioned the MAF a certain way for a reason.After having my stang plugged in the ford dianostic computer,i left the MAF right were Ford intended it be,then still didn't like how the stang ran with the CAI,then out that came too.Back in went the factory system without the silencer,and with a K&N air filter,and stang never felt better.
a non wideband o2 sensor is accurate for that. but at WOT the stock 02 is usless. the 02 is tuned for 14-7-1 air fuel ratio. it is very accurate near there but is wildly inaccurate lower than or higher than 14.7.1
i really recomend a wideband setup with a power adder.. a wideband will let you know what the a'f ratio is .. where the non-wideband is just good for letting you know it's richer than stochiometric.
That is correct. The eec completely cuts fuel at the injectors on decel after a short delay, and only at speeds over 25mph. After I put my supercharger on it was much more noticable for some reason and was almost jerky when it kicked in. I turned it off and it is sooo much smoother now, but at the cost of a few mpg...
yeah this is a part of the eec strategy. my car is almost stock so i don't notice it that bad.
While reading the plugs can give you a general idea, you won't know if you're running lean at WOT unless you do full throttle pass and cut the engine and do a plug check [which I wouldn't recommend with aluminum heads]or if you have a lean spot at say 3000rpm, the plug readings may be masked if your a/f ratio is good everywhere else. If your not sure, take off the CAI or get a tune.
Also, you could have a friend turn your MAF and not tell you which direction it's pointing and see if you can tell where it's set from your seat-of-the-pants meter, or if it's just the placebo effect. :D
