  • SVT Tech Forum
How to trip an engine code??
  • Thread starter Thread starter Steve2kGT
  • Start date Start date Feb 23, 2004
Steve2kGT
782
Santa Clara, CA
Feb 23, 2004
  • Feb 23, 2004
You can see my other thread in here, but I'm having trouble starting my cobra. Have replaced the fuel pressure regulator, now have fuel pressure at the rails, have spark at both coils, have good starter, new battery, but won't start!! I'm figuring that the injectors aren't injecting, so possible bad computer. But a computer is $300+, and I'd hate to spend the money if I don't need it. I'm basically trying to see if the thing is working by at least tripping an error code. Right now I don't get any error codes back. Even if I unplug the MAF and throttle sensor, I still don't get error codes. Now I did try the same test on a 98 GT, but I just turned it to start, but didn't start the car. It didn't trip codes either.
So basically, what can I unplug in the engine bay so that I can definitely trip an error code to see if the stupid computer is working. Again, I can try to turn it over, but it won't start.
Help!!
(I'm trying to avoid the $200 dealer charge to do some tests)
Lsredy2kstang
Look, I'm special, dammit
Woodstcock, Georgia
Feb 23, 2004
  • Feb 23, 2004
Help!!
I tripped a code by not securing the ground to the fuel pump. It is located in the trunk on the driverside area.
Just let it loose. That is where I grounded my stereo and threw the code when it became loose and would not properly ground the pump. hopes this helps.
P
Repeated P2004 DTC trouble code with no apparent symptoms
  • poehitman
  • Mar 11, 2026
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Mar 12, 2026
poehitman
P
Engine Code 41 again
  • Creomod
  • Jul 7, 2026
Fox 5.0 Mustang Tech Jul 11, 2026
Mcmahst
  • brandyn200
  • Jun 20, 2026
AeroCoupe
Engine Another no start after washing engine bay
  • bruno
  • Apr 26, 2026
Fox 5.0 Mustang Tech May 7, 2026
AeroCoupe
K
Electrical 2000 GT Intermittent Engine Shutdown In Motion - DTC U1262
  • kenster1092
  • Apr 13, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Apr 24, 2026
squeak93
  • SVT Tech Forum
