How useful are these supporting-role engine components?
So all the Cleveland engines that Ford sold in the 70s lost pressure on the right side lifter bank? That would mean they didn't last very long. Yeah I believe that. :rlaugh:
Sorry, but Cleveland oiling myths are a real pet peeve of mine.
They don't loose pressure to the point where there's damage at normal] operating rpms, but they DO lose pressure, this is bled off around the lifters in their bores. I've seen many Cleveland and 351M/400's that would register "zero" lbs oil pressure at idle and still run fine in normal] applications. I stress the word "normal" for a good reason. If oyu're not going to hotrod or dog on one, and don't mind a zero reading in oil pressure at idle speeds, by all means use the std volume pump. The last 400 I had would still register less than 20 lbs pressure at idle(hot) with a HV pump and a bypass hose from the front to the rear oil pressure port. There's no myth about this, it's a well known fact.
1) Aftermarket, SFI approved harmonic balancer=not needed, but if you are putting on a new balancer anyway it is not a bad investment. as stated summit racing has an inexpensive one
2) Windage tray=help keep oil in the pan and not wrapped around the crank. really only needed if you are going to be turning over 3500 rpm on a sustained basis. not needed for the street.
3) Stud girdle=for the horsepower level you are at you dont need one.
4) High volume water pump or water pumps with impellers=for your application you dont need this. as DH suggested get one from a taxi or police unit.
5) High capacity oil pan=you dont need this for the street, but two extra qts of oil will aid in cooling the engine since the oil will run cooler as it has more time to transfer its heat to the pan. just dont use a chrome pan.
6) High volume oil pump=unless you have large bearing clearances you dont need a high volume pump. in fact they cause problems like twisting oil pump shafts(if you use the stock one and you are a fool if you do), and sheared distributor gears.
7) High performance gaskets=felpro makes a few good lines of gaskets. i like the permatorque line best
as for the argument about the cleveland oil pumps, it is NOT a high volume pump, it is a high pressure pump that is used. the best thing is to use a restrictor kit and a standard pump for the street, and a high pressure pump for the track.
AFR 185 and stealth are great choices.
As for the items in question,
1)SFI balancer - Not needed for your application but a new or nice replacement might not be a bad idea depending on the condition of your current one.
2)WIndage Tray - I would suggest one, it isn't expensive and reduces the ammount of oil from splashing up against the crank, also reduces frothing effect.
3)Stud Girdle- not needed and aren't extremely effective anyways other than keeping the caps from walking or if your motor does split, keep it mostly together.
4)High volume waterpump- I would suggest one. Stay away from Milidon, they do not flow enough water at idle which is where you need it. Stuarts or edelbrock would get my vote.
5)High volume oil pan- not needed. May help your cooling but also kills ground clearance. Better off with an oil cooler(adds a little more oil and actively cools it too.
6)High Volume oil pump- not needed on the SBF in your application
7)Headgaskets- Fel-pro replacements will work fine for you but I cannot comment on their higher end but possibly lower grade line. Cometic and Graphite headgaskets seem to do pretty well but I don't have any experience with those.
Good luck with your buid. I have a feeling that you will be over 400hp with your build... at least have 400 effortlessly with a soon to be broken T5. hehe
Kevin
Kevin
Ha, yeah thats been going through my mind pretty much constantly... should I do the engine build as planned, knowing that I'll be pulling out my T5's corpse at some point thereafter and maybe finish it by May, or do I just wait a little longer, do the job right and replace the T5 with a gforce/astro T5 while the engines out?
Okay the choice shouldn't be that hard but I've been waiting to do this engine build for like 5 years, I don't want to wait another month or two :(
I think the verdict is that a higher volume water pump (either an aftermarket or a police intercepter version), a windage tray, and a balancer would be good ideas. Anything else I should consider? :cheers:
Just run the T5, chances are you won't have much traction in a light 66 so just watch the hard shifting. T5 can last but use the abuse spareingly. Either way if you do have to do an upgrade to a gforce, all the internals will be replaced anyways. You can also pick up a t5 case for cheap and have that done in the meantime.
Kevin
why are ya bagging on the print-o-seals D? i've used them almost exclusively on all the motors i've built and never had a problem with any of them.
your original afr 185, stealth and matching cam combo sounds like a good one to me. you could probably get away with the 165's if you use a mild enough cam or go with the competition ported 165's, otherwise i'd stick with the 185's. i was plannning on using the comp ported 165's on my eventual long rod 351w but mostly because i was going more for overall efficiency/longevity/economy rather than just power, sounds like you're wanting power more than efficiency/economy. i ended scrapping the plans for the AFR's altogether though and have since decided to run a set of FRPP x-305 heads with 64cc chamber and pedestal mount rockers so i can use a set of 1.7 cobra roller rockers and keep the compression down to around 10:1 and be able to use my original 69 block and the KB hypereutectic pistons for the shorter 9.48" deck height block. this will be going in my 69 cougar eventually and i'll be relying on the proceeds from the sale of the 69 GT coupe after we take out the down payment for a house which will eat about half of that money so the budget will be pretty tight and the FRPP heads are about 600 bucks cheaper than the 165's.
I was so impressed with Print-O-Seal gaskets back in 1981 that I put a set on a flat-top piston 289, torqued them down and left it for 3 days. Then I removed the heads, swapped the gaskets to the oposite side of the block, reinstalled and torqued the heads and ran the engine for 10,000 miles without a problem. It wasen't util I drove back from Atlanta at close to 100 mph and never less than 80 that they failed.
The only time I've had a problem with the Print O Seal head gaskets is when using aluminum heads on an iron block. I would always get the sweet anti freeze burning smell once the engine warmed up. I'm sold on Cometic MLS gaskets. A little more $, but incredibly tough, reusable and perfect for Aluminum heads on an iron block.
After the Printoseal gasket failures with my Canfield heads, I used the expanded Graphite Felpro 5.0 gaskets coated them with Copper-Kote. These have been on my 331 now for two years. Got the motor up to 250+ degrees the other day (need to install an auto switch in the Comet for that) with no ill effects. I did cool it down before killing the engine though. Coolant is 1 gal antifreeze with the balance tap water.
I would just keep the Distro and update the electronics. It doesn't sound like you are going to be winding out the motor to merrit the cost. At least it's one of those things you can replace later pretty easily if you can justify it.
Kevin
