how'd you tuck the tweecer back into the kick panel?
Black95GTS
1,644
Marlborough, MA
I have the TwEECer installed and am making successful tweeks. But I can't get the EEC with the tweecer attached back into the kick panel location! How did you guys remount the tweecer in the kick panel? After attached the main cable which is held in by the 10mm bolt, I can't slide the damn computer with the cable attached into its former slot because the tweecer unit adds an inch or so to its height. I can get it in there, but then the kick lanel won't slide all the way back on.
thanks,
Adam
I've seen so many different methods from all kinds of peeps so I would have to say there is no right or wrong way ............. just what you can make happen for you will work.
I just kinda bent the white plastic bracket in such a way that I could put one screw back in to hold things in place.
I think Dave has the best way cause its the easy way, lol.
Grady
