- Mar 30, 2005
- 4,749
- 95
- 134
Its the front hub bearing assembly on one side or the other.
To verify raise wheel and see if there is any "in and out" play at all. There should be none. Give the wheel a spin, does it grind? When you try to spin the wheel it can be very hard to spin, that's normal. You are not guaging spin resistance you are listening for grinding sound.
I had to replace mine on both sides, here is what the part looks like:
