Howling Noise From Air Filter Box
Pizzaman
56
Hello everyone, hope all are well. I have been able to keep my mustang well maintenanced and so I hadn't been on asking for help for quite some time, until now. I have been having some howling noises coming from the air filter box. This is a K&N Filter in the factory box into the fender. The howling noise which can be heard a block away or so is only active inbetween 1k and 2k rpm's and generally only when little or no throttle. Originally I would only hear it while driving but it has progressively gotten worse and now will howl in park. I did a google search and found this issue abundant within the Ford SUV's forums, and most of them mention replacing the IAC valve. I wouldn't have thought this as the problem. I took the box/filter apart and found that the rubber seal on the K&N filter was loose, not fully attached. I figure this is the problem, but before I replace it I thought I would take a shot on here and see what the "pros" thought. Thoughts? Thank you.
It very well could be the IAC.
Look at the hose between the IAC and the intake tube. Does it still have the box piece, or is it just a piece of hose?
The howling comes from the resonant frequencies that the incoming air can cause in the IAC and IAC inlet hose. Something like when you blow over an empty bottle. That's why it has a box in the inlet hose from the factory, to break up those resonant frequencies. My car used to do it, but it was from that inlet hose; with the way my supercharger is, I couldn't run that box and had to just go with a piece of 3/4" hose. It used to would howl like crazy, just like what you're describing. Touching the gas would often make it go away. To solve it, I put a smaller piece of hose inside my 3/4" hose. Still flows enough air for idling, but that different inner diameter breaks up those frequencies. It still does it on occasion, but it is much quieter and I think I'm the only one that would even notice it.
That being said, I've read many times that the IAC itself can cause this to happen. So if you still have that stock box on the intake, I'd guess the IAC is what the problem is.
