  • 1994 - 1995 Specific Tech
HP increase??
  • Thread starter Thread starter 95YellowGTbeasT
  • Start date Start date Sep 15, 2004
95YellowGTbeasT
605
South Carolina
Sep 15, 2004
  • Sep 15, 2004
Will I see a Increase in power by switching my B cam to an X cam???
Thanks
Nick
W
wytstang
Mustang Master
Mar 14, 2004
4,988
Summerville,SC missing South Fl. weather :(
Sep 15, 2004
  • Sep 15, 2004
After you fly cut the pistons you should. I have two friends running them in the foxes and they have a rough idle but both cars do scream.
95YellowGTbeasT
605
South Carolina
Sep 15, 2004
  • Sep 15, 2004
Why do i have to flycut my pistons?
Nick
W
wytstang
Mustang Master
Mar 14, 2004
4,988
Sep 15, 2004
  • Sep 15, 2004
Piston to valve clearance. The x cam has a .542 lift both of my buds had to have their piston fly cut for clearance. Stock ported heads with 1.90int 1.60 exh. Chances are you will have the same issues.
95YellowGTbeasT
605
South Carolina
Sep 15, 2004
  • Sep 15, 2004
max valve lift on my heads are 600?? will i still have to fly cut them?
Nick
W
wytstang
Mustang Master
Mar 14, 2004
4,988
Sep 15, 2004
  • Sep 15, 2004
The problem is not the heads is the clearance between the the valves and stock pistons. You really don't wont a piston to smack into a valve. If that happends one of two things will happen. One you bend a valve, Or two you punch a hole in your piston.
95YellowGTbeasT
605
South Carolina
Sep 15, 2004
  • Sep 15, 2004
Do you know how much it would prolly cost to get the pistons fly cut??
Nick
W
wytstang
Mustang Master
Mar 14, 2004
4,988
Sep 15, 2004
  • Sep 15, 2004
I have no clue. My friends knew the guy and got the job done for a crack head price.
95YellowGTbeasT
605
South Carolina
Sep 16, 2004
  • Sep 16, 2004
Whats the biggest cam you can put in a stock block without having problems??? is it 512???
Nick
GTJake
3,049
Ann Arbor, MI
Sep 16, 2004
#10
  • Sep 16, 2004
  • #10
Lift is not such as concern as duration is. All the tolerances stack up: timing chain, production tolerances in the pistons, head gasket thickness. It's best to just clay the pistons and find out.
Jake
95YellowGTbeasT
605
South Carolina
Sep 17, 2004
#11
  • Sep 17, 2004
  • #11
the X cam is the exact samething as a b cam but the x has more lift.
Nick
Grn92LX
Fidanza Man!
6,819
64
129
New York
Sep 17, 2004
#12
  • Sep 17, 2004
  • #12
Nick
Thats an oxymoron if I ever heard one
If your gonna swap out that pathetic B cam, why not put something in thats will work with what you have? Seems like the anderson B25 cams works great with those heads. A dude on corral made 299hp and great tq and under the curve with a combo just like you, un touched P heads and a street intake. hate to admit it, but the car made what I do and what majority of afr/fti guys make but with a cheap $300 iron head. It ran the # at the track too, high 7's @ 87 if I remember correctly.
D
Electrical Weird door wiring issues
  • Dakar09
  • Oct 20, 2026
Dakar09
D
G
Octane on the 5.0 Coyote
  • gray owl
  • May 17, 2026
  • 2015 - 2023 (S550) Mustang -General/Talk
2015 - 2023 (S550) Mustang -General/Talk May 27, 2026
Bullitt347
Supercharger and What else do I need? 1990 Saleen Vert 5spd
  • AlbertaGolfer68
  • Aug 18, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 27, 2026
General karthief
F
Ford 460 swap
  • Ford460
  • Sep 13, 2026
Ford460
F
A
Discussion on mild budget build/ top end
  • Acesario
  • Feb 21, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Feb 23, 2026
General karthief
