HP numbers from blown cars with stock cam
LXSTASY
932
Long Island, NY
I was curious what the dyno numbers were with the stock cam (doesnt matter what else is stock or not) and a supercharger.
I am debating on getting a vortech to install along with AFR 165's and my ported cobra intake. I was thinking about leaving the stock cam for now because I have heard it is not that bad of a blower cam.
Please post numbers of your set-ups with a blower and using the stock cam.
Dan
Dan I can see you easily hitting low 400's with stock pulleys and tuning. Just keep in mind if you run an fmu and 24# injectors you'll be seeing 100+ psi fuel pressure. I'm pretty sure you run stock injectors, so if you go blower route, buy some 42's or 50's and sh it can the fmu.
A friend of mine built a car for Real Street. A4 block with unported TW heads and a Holley intake and a Novi 2000 running 24 lbs of boost with the stock cam in a 310 CI motor. It made 620 RWHP.
I think with an S-Trim and your combo you could easily see 450 RWHP with a safe tune. I would not go anymore than that with the stock block.
42 lb. injectors and Pro-M 80 mm with no FMU should work just fine.
Good. I figure if I stick with the stock cam I can save some money and make good power without getting into another short block. Anything over 400 less than 450 I would like to make and I think that I could do it with a good tune. Now I need to figure out my job situation which is looking good at this point to drop the bills on the mods.
So 400+ is attainable?
