I've been thinking and in a 1/4 mile race what would win car a or car b
Car a has 500 hp and 400 ft/lbs
Car b had 400 hp and 500 ft/lbs
Ruckus46Gt said:same powerband...........same everything except for hp/ft/lbs differ
That is some good info, but what is the answer to his question, who wins A or B? Sorry you did answer in post above it, I did not see it was the same person.cougar694u said:More to read:
Maximum Acceleration vs Torque
I'd like to think that torque is an intuitively easier concept to understand. If that were true, though, then more people would understand the relationship between torque, horsepower, and vehicle acceleration. In reality, none of it is intuitive. If it were, Newton wouldn't be considered the Really Great Guy that he is.
The classic mistake is to conclude that the fastest way down, let's say, a 1/4 mile drag strip is to keep the engine RPM at the torque peak (or as close as possible). The technique is usually stated as "shift just after the torque peak", or "shift N RPM above the torque peak so you are N RPM below the torque peak in the next gear when you finish the shift".
Unfortunately, *engine* torque does not tell you the full story. What matters is the torque *delivered to the tires*, including the effects of the transmission. We all know a car does not accelerate as hard in second gear at peak torque RPM as it does in first gear. The transmission amplifies or multiplies the torque coming from the engine by a factor equal to the gear ratio. So to determine how much the car is accelerating at a particular instant, you have to know both the torque output of the engine as well as the gear ratio.
To figure out your shift points knowing only torque, generate tables of transmission output torque vs. RPM for each gear. To get transmission output torque, multiply the engine torque by the gear ratio. You are simply comparing gear to gear, so the final drive ratio can be ignored. You may also need to know the relationship between RPM in one gear and RPM in another gear (which is RPM * (gear2ratio/gear1ratio) at any particular vehicle speed.) Then it's easy to see what shift points to choose to maximize your transmission output torque at all times.
Maximum Acceleration Vs. Power
OK, so what about power? As has been noted by a previous contributor, Power (hp) = Torque (ft-lb) * RPM / 5252. Note that power is also force * velocity, specifically:
Power (hp) = Force (lb) * Velocity (MPH) / 374
That's net horsepower, which is engine power minus losses like transmission and tire friction. The force is the sum of the longitudinal forces at the contact patches of the two driven tires.
Hmmm... P = F * V ...rearrange to get F = P / V ...
that means that you get the maximum force pushing the car if you maximize your *Power* at any given velocity. This gives us another useful rule:
Shift to maximize engine POWER, not engine torque!
This is *exactly* the same as saying "shift to maximize transmission output torque". But it's a little easier to apply.
To the Point
Torque and power are (almost) flip sides of the same coin. Increasing the torque of an engine at a particular RPM is the same as increasing the power output at the same RPM.
Power is just as useful and relevant in determining vehicle performance as is torque. In some situations it's more useful, because you may not have to play with gear ratios and a calculator to understand what's going on.
A car accelerates hardest with gearing selected to stay as close as possible to the engine *power* peak, subject to the traction capability of the tires.
