Hpipe
  • Thread starter Thread starter IntenseBlue
  • Start date Start date Aug 12, 2005
I
IntenseBlue
946
  • Aug 12, 2005
I'm about to remove my Hpipe in the morning and I was wondering what this tube that ran from it to my air conditioning system was. Anybody?
HISSIN50
34
129
Aug 12, 2005
  • Aug 12, 2005
a tube runs from the smog pump to the cats.
L
luckythirteen13
648
Anaheim, CA
Aug 12, 2005
  • Aug 12, 2005
there is a pipe that runs from your smog pump, not your a/c
NosPony
278
Canton, Il
Aug 13, 2005
  • Aug 13, 2005
The tube is used to transfer fresh air into your exhaust. The pump takes fresh air and puts it into your exhaust to make it "cleaner".
tunedin302
I AM the law!!!
Jul 29, 2004
1,251
Pennsylvania
Aug 13, 2005
  • Aug 13, 2005
You need to use heater hose with a couple band clamps to connect the new return line on your H-pipe to the EGR return line. This line will require cutting from the old H-pipe. I suggest you make this cut as close to the H-pipe as possible and use a pipe cutter. Good luck.
bubba-dough
1,044
Indiana
Aug 13, 2005
  • Aug 13, 2005
The tube comes from the smog pump and pumps fresh air into the cats to help burn the exhaust gases faster and more effiecantly thus getting cleaner emmisions.
T
TheUser
1,859
Springfield, MO
Aug 13, 2005
  • Aug 13, 2005
I think he could probably just use the stock tube. I've had mine off before and put it back on. Mine was just clamped onto the Hpipe...the end of the tube is slit so it can be made larger at the end and slide over the h-pipe end.
M
macx
228
SE Missouri near Cape Girardeau
Aug 13, 2005
  • Aug 13, 2005
http://www.lincolnsonline.com/article91.html
tunedin302
I AM the law!!!
Jul 29, 2004
1,251
Pennsylvania
Aug 13, 2005
  • Aug 13, 2005
Yup can do that too. I ran mine like that for about 10 years and just recently put in the heater hose. My Bassanni came with heater hose. It's very easy, flexible, and seals tight. I won't go back.
Engine Keeping O2 sensors lit with long tube headers
  • keel
  • Jul 30, 2026
Fox 5.0 Mustang Tech Aug 21, 2026
Qtrhrse23
Brakes Front Brake Hardline Routing
  • 93Nifty
  • Sep 11, 2026
Fox 5.0 Mustang Tech Oct 11, 2026
limp
Fox Removing smog only questions
  • 91GTstroked
  • Sep 12, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 14, 2026
91GTstroked
Electrical Code 29 again
  • Creomod
  • Jul 31, 2026
Fox 5.0 Mustang Tech Aug 3, 2026
Creomod
L
A/C doesn't work after long drive
  • lking78
  • Jun 23, 2026
  • SVT Tech Forum
SVT Tech Forum Jun 30, 2026
