HPX ignition problems....
  • Thread starter Thread starter tuckerman
  • Start date Start date Jul 13, 2010
T
tuckerman
south carolina
Jul 13, 2010
  • Jul 13, 2010
Anybody else using the Electromotive HPX ignition? It came in my 93 GT when I bought it and it worked fine until my 308 swap.......now I cant get it to fire. If nobody has any experience with this, can a good shop be recommended somewhere in the Carolina's or northern Georgia? Thanks for any help.
jrichker
StangNet's favorite TOOL
Mar 10, 2000
27,512
2,813
234
Dublin GA
Jul 13, 2010
  • Jul 13, 2010
Check out HPX by Electromotive, Inc. and let us know if this is what you have on your car...
More manuals for download...
http://www.electromotive-inc.com/manuals.html
T
tuckerman
south carolina
Jul 14, 2010
  • Jul 14, 2010
yes, thats the one. I have that manual, and have gone over everything 10 times. The set-up is really simple, thats why I was hoping to find someone that has used them before to tell me what I am missing.
T
tuckerman
south carolina
Jul 14, 2010
  • Jul 14, 2010
Just in case it helps, this is the rest of my engine build
308 DSS pro-bullet block w/ DSS pro-lite pistons with valve reliefs
Windsor Jr's fully ported w/2.02-1.60 stainless valves, dual springs
Crane Powermax blower cam (.542/.563)
lunatai lifters
Comp Cams roller timing set, Comp cams pushrods
Pro-Comp 1.6 roller rockers on ARP studs
Melling HV oil pump, ARP pump shaft
ARP hardware thoughout
Mac longtubes, mac prochamber, flowmasters
BBK pulleys,
I kept the Demon blow-thru carb, and the Procharger (still at 15 lbs). If I cant get HPX to work right, I guess I get a distributor and ignition box and convert it back........It makes me drool to look at it sitting in the car......now if she would only fire.
jrichker
Mar 10, 2000
27,512
2,813
234
Dublin GA
Jul 15, 2010
  • Jul 15, 2010
You need 12 volts to input, pulse from the pickup and a ground. Get out your DMM and start looking for missing voltages, ground or pulse.
T
tuckerman
south carolina
Jul 15, 2010
  • Jul 15, 2010
I have good power and ground. Brand new Red-Top Optima (1000cca, 800ca, 100rc) brand new 3g (120a)alternator, brand new starter, and I bought a new pick up sensor just to try it. Everything powers up like it should but I can not get a consistent signal from the crank sensor.
Last night it started for about 7-8 seconds and died again, then I have ZERO signal from the crank sensor again. I am going to try some stuff again tonight and I'll let you know if anything works. Thanks for the input
  • dan50
  • Jul 18, 2026
dan50
J
5.0 ignition wiring help
  • Jetscat7
  • Nov 25, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Nov 25, 2025
M
Engine Unexplainable Exhaust Pop and Gurgle
  • Mrnissen122
  • Feb 14, 2026
Fox 5.0 Mustang Tech Feb 18, 2026
Preparation for Holley Terminator X install – Foxbody 306 (electrical fan, alternator, MSD Ignition, etc)
  • So_Flo
  • Mar 1, 2026
3K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Mar 4, 2026
General karthief
Resolved Ignition switch questionable
  • Dontknowchit
  • Mar 14, 2025
Fox 5.0 Mustang Tech Jun 18, 2025
General karthief
