Just in case it helps, this is the rest of my engine build
308 DSS pro-bullet block w/ DSS pro-lite pistons with valve reliefs
Windsor Jr's fully ported w/2.02-1.60 stainless valves, dual springs
Crane Powermax blower cam (.542/.563)
lunatai lifters
Comp Cams roller timing set, Comp cams pushrods
Pro-Comp 1.6 roller rockers on ARP studs
Melling HV oil pump, ARP pump shaft
ARP hardware thoughout
Mac longtubes, mac prochamber, flowmasters
BBK pulleys,
I kept the Demon blow-thru carb, and the Procharger (still at 15 lbs). If I cant get HPX to work right, I guess I get a distributor and ignition box and convert it back........It makes me drool to look at it sitting in the car......now if she would only fire.
