Huge Tranny Problem
  • Thread starter Thread starter Robert_68
  • Start date Start date Aug 22, 2004
Robert_68
44
  • Aug 22, 2004
Ok Im new to mustangs so bear with me. I just bought a used, 92, 5.0 stang from a friend but it had a problem with the gears. When I shift into second I'd get a really bad grind. I have to go from 1st to neutral and wait till the rpms drop really low and THEN into second. Can anyone help me out with a solution. Thanks.
88hatchblack
163
Willard, Ohio
Aug 22, 2004
  • Aug 22, 2004
sounds like bad synchros
blk92stangg
583
Hawaii
Aug 23, 2004
  • Aug 23, 2004
I would say it IS bad synchros, and the only way to get that fixed is to rebuild the darn thing. I have heard its not too hard to do. Try doing a search for a T5 rebuild. GL. BTW, the synchros are what slows/speeds up/down the gears and collar so that they can mate without grinding. When the synchros are bad, the gears don't match speeds, so they grind. check out how things work for more info.
jrichker
StangNet's favorite TOOL
Mar 10, 2000
27,512
2,813
234
Dublin GA
Aug 23, 2004
  • Aug 23, 2004
The second gear synco has gone over to the enemy camp...
I don't know how you feel about the DYI thing when it comes to gears, some people don't like the idea of working on transmissions. If the DYI transmission fix idea isn't something that you would rather leave to someone else, here are some resources:
See http://www.ttcautomotive.com/English/onlineorder/product.asp to download a FREE service manual for T5 or Tremec 3550
You will need the Adobe Acrobat viewer which is also a free download – http://www.adobe.com/products/acrobat/readstep2.html
See http://www.hanlonmotorsports.com/ or http://www.ddperformance.com/index2.htm for parts
A T5 rebuild kit with syncros, bearings and other small parts costs about $160. It does not include any gears or shafts.
http://cartapes.com also has a video on how to rebuild your T5 or Tremec. It costs less than $20, and is worth every penny of it.
I did a Tremec 3550 rebuild, and it wasn't that difficult. The video was an immense help, and I would recommend viewing it. At $20, it will give you an opportunity to look and decide for yourself if you think that it is something you want to try to do.
You will also need a magnetic base and dial indicator to measure the endplay ($20-$40). See http://www.mscdirect.com/PDF.process?pdf=1312&Keyword=Y
Robert_68
44
  • Aug 23, 2004
Thanks alot guy, Ill prob do this myself with some help. If theres anything I should know through your tirals and errors, let me know. THANKS
T
Drivetrain TREMEC TKX 1–2 Grinding Issue at ~4,000 Miles + Poor Warranty/Customer Service Experience
  • Ttopfoxguy
  • Oct 10, 2026
Fox 5.0 Mustang Tech Oct 15, 2026
JMG9350
J
Ford truck engine swap issues
  • keel
  • Jul 7, 2026
  • Other Auto Tech
Other Auto Tech Jul 13, 2026
General karthief
W
Speedometer and shifting issues
  • wyatt-tetro891
  • Aug 17, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 18, 2026
wyatt-tetro891
W
K
TKX Transmission Shifting Problem
  • KWC156
  • Jun 23, 2025
  • Other Auto Tech
3K
Other Auto Tech Jun 13, 2026
427nostang
J
Emission problems
  • jls.zmmr
  • Feb 5, 2026
  • 1994 - 1995 Specific Tech
1994 - 1995 Specific Tech Feb 7, 2026
AeroCoupe
