Hunting Idle, Random Stalls, No Power...
A great tech article on how to adapt an Explorer 65mm Throttle Body to work on a stang 5.0
http://www.veryuseful.com/mustang/tech/engine/ConvertingExplorer65mmTB.pdf
If you look at the 2nd picture, on the bottom of the picture, you can see a screw. That screw adjusts the BASE idle speed.
You may need to take off the tube going to the TB to see it and get it.
To set the timing:
http://www.moddedmustangs.com/forums/how-to-bump-up-your-timing-vt294.html
A Chiltons will help with more info. You'll need a timing light.
