I have the
hurst Billet and I do really like it. You cant beat the look and feel of a hurst.
That said. It does rattle. There is a rattle fix mentioned in the install directions for the MGW shifter, found on the MGW website. You may want to check that out. Whether you car installing the MGW or the Hurst, the rattle fix should be the same, as it is coming from the e-brake handle. I have not done that yet. I've just gotten used to the rattle, and over time, I think it has reduced. I am not 100% sure the MGW fix will work on the Hurst, but its very cheap and easy to do (provided you have some dynamat)
You can just dynamat the crap out of the entire center console area. I am planning on doing that someday. That should reduce transmission noise in the cabin, and maybe cure some rattles in the process.
