hurst stick on Pro-5.0
hren59
27
San Diego, CA
This stick is specified for stock T-5 shifter or Hurst super comp, will this stick also replace the one on a Pro-5.0 shifter on a 3550?
"1987-92 Mustang with Factory Console and T-5 Transmission
530-538-0036"
I'm not sure on your specific application, but to use the stick from the factory Hurst shifter on my TKO600 when I upgraded to a Pro5.0 I had to drill out the holes on the stick. The Pro5.0 used slightly larger bolts on the same center to center.
Stan
I have a Pro-5.0 handle on a HURST shifter. Exactly the opposite of your combo...lol....but it bolts up and works fine. I like it a lot. I want an MGW, but don't wanna spend $200 on it right now.
I did it a while ago on my t5 trans.
One side had to be drilled out.
I did it because my hurst handle had a bend it in that i liked, so i put it on my pro 5.0 shifter.
