HVAC question
  • Thread starter Thread starter madweazl
  • Start date Start date Jan 6, 2012
M
madweazl
203
Woodbridge VA
Jan 6, 2012
  • Jan 6, 2012
This morning I turned the heater on and hit the recirculate button (gotta keep that new car smell...) and noticed that it had turned off (recirculate). Hit it again and made sure to observe the time. It turns off after 5 minutes. I found an article for a Tacoma and it looks like if you hold the button for a few seconds recirculate will stay on. I looked through the manual but didnt find anything like this. Anyone know if there is a trick to keep it on?
M
madweazl
203
Woodbridge VA
Jan 9, 2012
  • Jan 9, 2012
Well, I want able to find anything that worked to keep recirculate on while using the heater (stays on just fine with the a/c). Did run into another issue this morning though; with the heater on and selected the vents at your feet, I would get a split between defrost and foot even though I only had foot selected at the control panel. Is that normal as well?
LittleT
14
Jacksonville NC
Jan 10, 2012
  • Jan 10, 2012
It will only work with the AC on, it helps the AC cool the car better and not work so hard on hot humid days.
M
madweazl
203
Woodbridge VA
Jan 10, 2012
  • Jan 10, 2012
I'm well aware of how it functions, just seems weird that it will only stay on for 5 minutes with the heater on (just like the a/c, it heats up quicker when you recirculate the air). Biggest reason I use it is because some areas are stinky out here on the way to work. The last two days I've remembered to turn it on in that spot.
ATISTANG
104
  • Jan 12, 2012
My car blows out the defrost when you have just feet selected also. It might be common but its not normal
As for the recirculation, if your running the heat and recirculation for too long you will probably start fogging up the windows
Art161
130
San Francisco
Jan 12, 2012
  • Jan 12, 2012
No clue as to why the recirculation is working that way.
According to the Ford Workshop Manual for the 2007 Mustang, if the FLOOR mode is selected, a small amount of air will come out of the defrost and side demister vents. If the DEFROST mode is selected, a small amount of air will come out of the floor vents. Go figure.
M
madweazl
203
Woodbridge VA
Jan 13, 2012
  • Jan 13, 2012
Consistent with the 2012 too. If you select defrost it blows considerably harder from the defrost vents.
ATISTANG
104
  • Jan 14, 2012
I dont mind that it does it, what sucks is that if i have it set to floor and turn the fan past 2 then i get a loud air noise from the defrost vents
M
madweazl
203
Woodbridge VA
Jan 14, 2012
  • Jan 14, 2012
Yes! All the vents are very loud compared to my other vehicles actually.
F
Ford-a-tude
#10
  • Feb 2, 2012
  • #10
I have been meaning to ask this myself. My defroster vents blow while selecting feet only as well. I really hate this behavior. Not only does it dry out my eyes and my feet are cold but it also makes more noise.
Fordatude
E
2007 GT Stalls when lights or a/c turned on
  • ejscarfo
  • Jun 22, 2026
  • 2005 - 2009 Specific Tech
2005 - 2009 Specific Tech Sep 26, 2026
manicmechanic007
K
Engine 2000 Mustang GT - Fuel issue post-blown spark plug repair
  • kenster1092
  • Feb 26, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Mar 10, 2026
kenster1092
K
'04 V6 running rich excessively on both banks
  • 04DSGVert
  • Oct 26, 2025
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Oct 27, 2025
04DSGVert
M
  • mnky99
  • Sep 5, 2025
mnky99
M
D
Engine Coolant and Radio Issues
  • Don7Up
  • Sep 14, 2025
Fox 5.0 Mustang Tech Oct 4, 2025
Don7Up
D
