Hydroboost/ps pump issues?
  • Thread starter Thread starter AvalancheSVT
  • Start date Start date Apr 30, 2022
AvalancheSVT
573
37
49
Apr 30, 2022
  • Apr 30, 2022
so the car does really great, the only thing is that if i stand on the brakes (like in a way that you'd never do even driving spiritedly) the engine will die if at idle.
its really an edge case so it doesn't bother me too much but i would like to get this sorted.
any body got any ideas? its definitely the hydroboost or ps pump thing.
Mustang5L5
Mod Dude
Feb 18, 2001
43,317
18,036
224
Massachusetts
May 1, 2022
  • May 1, 2022
Do you have U/D pulleys at all?
As you press the pedal the load on the PS pump does increase. As you’ll note, applying unrealistic pressure to the pedal will increase load to the point the engine may stall.
I have hydroboost on my fox and note the same thing but it’s not an apples to apples comparison since mine is a retrofit and I do not have the same pump. I can load up the engine pretty well, but like you said, to do this requires leg pressure that I’ll never use during actual driving. My car stops well with very little pressure which does not load up the engine like it does of I stand on the pedal
I had an 03GT but it’s been years since I had it so I don’t remember how a new, stock new edge behaved.
AvalancheSVT
573
37
49
May 1, 2022
  • May 1, 2022
pulleys are all stock. there is a pressure relief valve internal to the pump which should open bypassing the pump entirely when it reaches a certain pressure. this is to prevent the system from overpowering the rotor and thusly stopping it (as far as I understand it).
so I set up a test. this is a power drill on the pulley with me pressing the brake pedal inside the car. it stops the pump every time.
View: https://youtube.com/shorts/NFnbvs-JWRU?feature=share
AvalancheSVT
573
37
49
May 1, 2022
  • May 1, 2022
Why is a pressure control valve necessary on a power steering pump?
Answer (1 of 3): Power steering pumps free flow hydraulic fluid till power steering Assistance is needed by turning the steering wheel. When turning the steering wheel in a hydraulic steering system fluid is restricted on one side of the system and cause the hydraulic pressure to rise on Desired ...
www.quora.com
Mustang5L5
Mod Dude
Feb 18, 2001
43,317
18,036
224
Massachusetts
May 1, 2022
  • May 1, 2022
Do you hear a hissing/buzzing noise from the relief valve prior to the pump load stalling out the engine?
AvalancheSVT
573
37
49
May 16, 2022
  • May 16, 2022
It was the tune. She runs great now.
Reactions: Mustang5L5
E
Finished my Fox Hydroboost Install - Tips
  • Engineer Duane
  • Apr 9, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- May 5, 2025
Engineer Duane
E
V6 to V8 Swap info
  • 02_2v_Curtis
  • Jan 11, 2026
1996 - 2004 SN95 Mustang -General/Talk- Jan 11, 2026
02_2v_Curtis
Need help asap
  • shaggyman65
  • Dec 24, 2025
1996 - 2004 SN95 Mustang -General/Talk- Dec 24, 2025
shaggyman65
M
Need help!
  • Masonevans726
  • Dec 17, 2025
1996 - 2004 SN95 Mustang -General/Talk- Dec 17, 2025
Masonevans726
M
Fox Fuel Pump Issues After Replacement/Upgrade
  • Ryu
  • Jun 23, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 13, 2026
Ryu
