Some searching has taught me that older continentals and newer 4.6L powered mustangs used hydroboost assist for power brakes.
I am interested in going this route myself. I have a manual TCP rack setup, but I still have my original PS pump and brackets that I could use strictly for the hydroboost.
Will the stock pump be too much or too little for the hydroboost?
What else do I need to do besides buy a late-model mustang setup and run a return and pressure line from my pump?
I just went through this same thing a few weeks ago where the BRAKE light would not go out. I followed the same instructions that you did with the same results that you had. Then my mechanic across the street helped me get it squared away. First, when they say 'cracked' they mean just barely cracked. Fluid will barely seep out when you put you foot on the brake. Second. you need two people. The person in the car needs to have the ignition in the "on" position and needs to keep an eagle eye on the BRAKE light - don't blink. Then he needs to VVVVEEEERRRYYY slowly press on the brake pedal. The instant the light goes out he needs to STOP pressing the brake and hold it there - do not move. Then the person under the hood needs to tighten the line up. If this doesn't work, crack the brake line on the other side of the dual cylinder and try again as the valve may have slid to the other side. It worked for me.
