I believe I'm running rich
_An
Morrisville, NC
Mornin!
The car seems to be running solid other than the following...
There is a nice smell of fuel or something that creeps into the passenger side of the car.
There is also an excess of the same smell leaving the exhaust. It seems a bit much even with it being cold (the amount of smoke that is) The smoke is white. My mom couldn't even stand following me from the restaurant last night X_X
My gas mileage is also averaging about 15-17mpg =)
I'll take a video of it idling to give you all a better idea of what I am trying to explain on my lunch break....
Thanks for your time regardless.
e303 cam
ho intake manifold
intake
flowmaster o/r h-pipe
flowmaster exhaust
msd cap
3.73 gears
110k miles
has never been tuned or been on a dyno
if any of that helps...
there is the link of the car warmed up at idle. outside temperature is 43F.
seems like the right exhaust is flowing slower than the left....
anyway. any help would be appreciated. thank you!
Start by diagnosing things instead of listening to wild guesses or throwing parts at a problem...
Dump the codes: Codes may be present even if the Check Engine Light (CEL) isn't on.
Dumping the computer diagnostic codes on 86-95 Mustangs
Revised 26-July-2011. Added need to make sure the clutch is pressed when dumping codes.
Codes may be present even if the check engine light hasn’t come on, so be sure to check for them.
Here's the way to dump the computer codes with only a jumper wire or paper clip and the check engine light, or test light or voltmeter. I’ve used it for years, and it works great. You watch the flashing test lamp or Check Engine Light and count the flashes.
Post the codes you get and I will post 86-93 model 5.0 Mustang specific code definitions and fixes. I do not have a complete listing for 94-95 model 5.0 Mustangs at this time.
Be sure to turn off the A/C, and put the transmission in neutral when dumping the codes. On a manual transmission car, be sure to press the clutch to the floor.
Fail to do this and you will generate a code 67 and not be able to dump the Engine Running codes.
attachment.php
attachment.php
What to expect:
You should get a code 11 (two single flashes in succession). This says that the computer's internal workings are OK, and that the wiring to put the computer into diagnostic mode is good. No code 11 and you have some wiring problems. This is crucial: the same wire that provides the ground to dump the codes provides signal ground for the TPS, EGR, ACT and Map/Baro sensors. If it fails, you will have poor performance, economy and driveablity problems
Some codes have different answers if the engine is running from the answers that it has when the engine isn't running. It helps a lot to know if you had the engine running when you ran the test.
Dumping the Engine Running codes: The procedure is the same, you start the engine with the test jumper in place. Be sure the A/C is off, and clutch (if present) is pressed to the floor, and the transmission is in neutral. You'll get an 11, then a 4 and the engine will speed up to do the EGR test. After the engine speed decreases back to idle, it will dump the engine running codes.
Your 86-88 5.0 won't have a working Check Engine Light, so you'll need a test light.
See AutoZone Part Number: 25886 , $10
Alternate methods:
For those who are intimidated by all the wires & connections, see Actron® for what a typical hand scanner looks like. Normal retail price is about $30 or so at AutoZone or Wal-Mart.
Or for a nicer scanner see Equus - Digital Ford Code Reader (3145) – It has a 3 digit LCD display so that you don’t have to count flashes or beeps.. Cost is $30.
Start with what Jrichker posted. But, do you still have all your smog equipement? If not, that is most likely your problem. I have no smog, and the smell is horrible (removed prior to purchase). Also, when it is cold, mine will smoke like that until it gets completely warmed up. Its most likely just steam and condensation leaving the exhaust, unless you really do have some type of problem.
Joe
