I can hear my valves.
Foxfan88
My Grandpa has great wood.
Sep 13, 2004
2,487
Miami, Ok
I can hear my valves, my oil level is ok.
It just doesnt sound normal.
or it could be spark knock.
I had a problem before but it was a slower tick, and showed up more under a load, this shows up when you give it some gas. Much fast, like the rockers or valves or or something. could it be my octane level? i have been running 87
i had 93 and i think it was better.
ALSO!
my gas guage broke yesterday, how do i fix/ replace?
does it happen at idle (no load)? worse when the motor is cold? dont forget that it could be an exhaust leak.
good luck.
start the motor cold and stick your hand around the hearder very very quickly to see if you can feel anything, it heats up REAL fast so do it quick. if you feel air blowing then its the gasket
you cant hear it at idle, cant tell if its even there or way tooo quiet to hear.
Also, does the gasket seal up right against the head good or is there space. becasuse there is quite a bit of space on the front most left header pipe
