I can't get in to Talk ?
I have the second set of heads to fix my car but for $450 I don't know if I want to pass this up !! I could put my cobra cams in the 5.4 and find some intake adapter's and rock a 5.4 > it's very timpting.
AND THANK YOU FOR FIXING THE TALK FORUM !!!!!!!!!
So I'LL post in this section >
What do you think of a 32v 5.4 out of a Nav I think? or was it a Aviator?
motor only has 56,000 miles on it >was thinking about swaping out my 4.6 for it > does anyone have a wiring diagram for the coil on plug set-up ?
dont know if you seen in wire diagram for nav/aviator the wires are reversed...it looks like the cobra is the same as nav...
hot wire in pin 2
result's are in it DID NOT THROW A TIMING CHAIN> it sucked in alot -- alot :jaw::jaw: of water and hydro locked and broke pistons and bent rods > great .... and I thought it was going to be bad :fuss: :fuss: :( so the motor is out and the in the back of my truck :dead: and I'll pull the car back home tomorrow > and it will sit till spring .... or till I decide what I'm going to do. :mad::mad:
