I cleaned the IAC, and now it's idleing wierd.
I cleaned my IAC two days ago, and it was dirtier than a whore on nickle night. After I cleaned it, I put it on the car and started it, and now it will idle at about 1500, and about 5 mins. later it drops to the previous idle (750ish). So then, I reset the computer, but that didn't change anything. I've turned down the idle on the throttle body, but that doesn't solve the problem.
After the car starts to idle correctly, I would turn it off and restart it, and it would idle fine. Yesterday I worked 7 hours, and when I went and started my car it jumped up to 1500 again. Today, when I stated up the car after work it was about 1000, and then when I got home it was still at 1000 in the garage. When I got a screwdriver to mess around with the idle screw on the TB, but then it started to idle correctly.
The car ran good before I messed with the IAC. I figured since it was 109k miles on it, no one cleaned the IAC. Any ideas on what has happened?
90mustangGT said:
A new gasket would have been a good idea. I would make sure the TPS is set to .99 and then disconnect the battery for a while so the computer can relearn.
After I started up the car and it was running at 1500, I tired checking the TPS. How am I supposed to turn it? I loosended the bolts, and I read that I am supposed to be able to turn it, but do I turn the whole senor?
They run around 50-60 bucks I think. You can buy just the gasket from 50resto and probably can pick one up at the dealership as well. As for as unsticking it I normally just clean mine with throttle body cleaner and a Q-tip. I would unhook the battery first like 90mustangGT said and then drive it and see if the computer fixes it itself. As far as the TPS I have never been able to tell any difference unless the sensor just has a dead spot in it. Last time I had to replace one I just put it on in the parts store parking lot and it has been fine ever since. You can do a search on how to adjust it if you won't , but I am not convinced it "really" affects anything by adjusting it.
Now my throttle doesn't seem to come down as fast. WTF? I reset the computer and it still does it. If I just give it some gas it will return to idle speed well. While when I'm driving and I push in the clutch or even pop it out of gear it go down about 200RPM, stay there for a second or two, then go to idle speed.
