Electrical I Fried Something
  • Thread starter Thread starter Olythekid
  • Start date Start date Jul 20, 2017
O
Olythekid
  • Jul 20, 2017
78 Mustang ii 2.3L 4 speed manual.
Trying to crank after winter storage, I had sparks at the bat + terminal when turning the key to start. Turned out my Starter Solenoid was falling apart rusted inside.
I replaced with a new one. I have power to the dash when turning the key to acc, but when I turn it to Start I hear the solenoid closing and I lose all power. When I disconnect and reconnect the battery only then I get power back. The starter was tested and working, grounds look good, the purple/blue wire connected to the 'S' terminal of the starter, nothing on the 'I'. The green fusible link out of the + of the starter solenoid doesn't seem to have fried as it connects to a tan wire that has 12V (and my gauges work anyway). Fuse box does not seem to have anything burned up.
What do you gurus recommend?
Adieu
Easy there, this ain't a dating site.
20+ Year Stangneter
Mar 7, 2002
9,531
5,187
224
Jul 20, 2017
  • Jul 20, 2017
Either the battery needs to be charged or you have a loose connection.
Reactions: jozsefsz
jozsefsz
1,243
332
124
Cleveland OH Area
Jul 20, 2017
  • Jul 20, 2017
Agreed, a shorted battery or loose terminal will act that way. If the terminal itself is tight to the battery, it may have corrosion in the part where it connects to the wire. The grounds may also look good but have corroded inside, most important is the thick wire straight from the battery to the block. You can help eliminate the options by trying to start it, letting it do its thing (don't reconnect and get it working again, leave it as-is), and then checking for voltage or ground at various points along the way.
LILCBRA
Mod Dude
Dec 6, 2005
6,577
5,594
194
Corn County USA
Jul 20, 2017
  • Jul 20, 2017
Sounds like a crappy connection somewhere. As stated, double check all of your connections and make 100% sure they aren't corroded or otherwise bad. Sounds like the terminal connections are the places to start. Good luck!!
O
Olythekid
  • Jul 20, 2017
Even with a battery from an another vehicle same stuff. When I undid the bulkhead connector to access the fuse box, the plug receptacle broke in 3 places. Dung nugget, got to be a good place to start. I wonder where I can source one. Maybe I'll have to go full 'painless'. Thank you for pitching in.
D
Mustang not starting
  • Dawry Ramos
  • Sep 12, 2026
  • 2015 - 2023 Specific Tech
2015 - 2023 Specific Tech Oct 3, 2026
Dawry Ramos
D
M
85 mustang 5.0 cranking in run position
  • Mamaclean
  • May 23, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 1, 2026
General karthief
F
Alternator Not Charging
  • Fri Guy
  • Aug 29, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 31, 2025
AeroCoupe
M
2004 v8 convertible
  • Mikeycrownvicluver
  • Feb 12, 2026
1996 - 2004 SN95 Mustang -General/Talk- Feb 15, 2026
Mikeycrownvicluver
M
92 5.0 almost starts
  • Steverino
  • Sep 23, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 25, 2026
General karthief
