  • SN95 4.6L Mustang Tech
I Got a Big tranny Problem
  • Thread starter Thread starter cj_scarletty
  • Start date Start date Mar 10, 2008
C
cj_scarletty
31
Madison N.C.
Mar 10, 2008
  • Mar 10, 2008
I just got a 97 mustang GT I'v been horsing around with it until something went wrong! It's in first gear. I can pull it back to secong gear and it feels like there is nothing there but I feel 3rd,4th and 5th. When put in nuetral it still acts like it's in first. When I try to put into reverse it won't go nowhere. It acts like it's in first and in reverse and is fighting each other. The mechanic I talked to said he thinks some kind of pin in the shifter assembly has been sheered or broke off and that is causeing this. A friend said could be shift forks are bent or broke. If anyone has had a problem like this please help this is my first mustang and im stumped
C
CENTENNIALSTANG
Houston
Mar 10, 2008
  • Mar 10, 2008
My 3650 did something like that i broke my shift fork and pins. My tranny was stuck in 4th gear. I bet you broke the pin, and you probly have synchro damage also. Get a TKO or rebuild yours. And put a stage 2 clutch in while you are at it.
Mustang92
SN's #1 1%er
Jun 6, 2001
6,467
South Florida
Mar 10, 2008
  • Mar 10, 2008
Shift fork is more than likely broke and when that happens other parts usually get damaged. Time for a rebuild.
Also just FYI shift forks can't bend they crack and break.
Bill
C
cj_scarletty
31
Madison N.C.
Mar 10, 2008
  • Mar 10, 2008
ok i hopefully find out tommarow what is broke. if shift forks are broke would a tranny out of a stock 01 cobra be a good replacment? if so what would i haft to chang to make it work? im really workn on a tight buget. does an aftermarket shifter help with the problem that occuerd with my tranny?
Miles
1,225
Burlington, ON
Mar 11, 2008
  • Mar 11, 2008
I'm no transmission expert, but if you're on a budget + can do the work yourself + it's a shift fork, they're pretty cheap to replace from what I've heard. Good luck
Mustang92
SN's #1 1%er
Jun 6, 2001
6,467
South Florida
Mar 11, 2008
  • Mar 11, 2008
I know the 96-98 Cobra T-45's have different cross member mounts so they aren't the same. You are better off looking for a stock t-45 or 3650 from a GT. Yes an aftermarket shifter with shift stops would help prevent the issue you had.
Bill
Car shakes when taking off help???
  • STANKYstangs
  • May 10, 2026
1996 - 2004 SN95 Mustang -General/Talk- May 27, 2026
LILCBRA
00 4.6L V8 new clutch won’t go into gear when on?
  • Timboslice
  • Aug 15, 2026
  • The Welcome Wagon
The Welcome Wagon Aug 21, 2026
T5 5th gear 89 gt
  • mac_55
  • Mar 19, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Mar 20, 2026
Mustang5L5
I
98 Mustang GT dying
  • ItsMason
  • May 14, 2026
1996 - 2004 SN95 Mustang -General/Talk- Jun 25, 2026
lenzgt
L
I need help with an 06
  • boviske underwood
  • Oct 30, 2025
  • Services - Tuning, Welding, Mechanic, Body Work...
Services - Tuning, Welding, Mechanic, Body Work... Oct 30, 2025
boviske underwood
