I got a flat tire for Xmass
  • Thread starter Thread starter scupking
  • Start date Start date Dec 26, 2007
scupking
1,186
Enfield, CT
Dec 26, 2007
  • Dec 26, 2007
Well on my way to work today there was a nice chunk of ice on the road that I didn't see, I hit it at 50 and my tire blew up, instant flat. So I pulled over, no rim damage. Now the funny thing is my girl friend bought me a jack and jack stands for Xmass. I had the jack in the trunk with me so I got to try it out. It worked but I don't no if I jacked it from the right spot. Where should you jack the car up? I don't have the manual in the car so I just took a guess.
Twista
510
@ the z00 in chicago
Dec 26, 2007
  • Dec 26, 2007
Consider yourself lucky. Saw a girl at about 12pm on a stretcher in the middle of the street because she got into an car accident on xmas.
but u jack it up from the rails on the side of the car... thats what i do.
scupking
1,186
Enfield, CT
Dec 26, 2007
  • Dec 26, 2007
Yeah that’s what I did. The rails are the 2 metal peaces that run the length of the car?
68stang351
850
9
39
Savoy TX
Dec 26, 2007
  • Dec 26, 2007
Don't feel bad man, I got a flat right front tire on Christmas eve and had to change it with the stupid scissor jack. Turns out that my car is out of line and the wire was showing around the inside edge of the tire, and the one on the other side was getting bad too.
So I got it home and put the rear wheels and tires on the front, and had to put my rear Prostars and MT Drag radials from my 68 on the rear of my 04 until I get money to buy a new set of tires.
streethorse
1,042
Dallas Texas
Dec 27, 2007
  • Dec 27, 2007
There is a specific spot right behind the front wheel, and in front of the rear wheel
on the rail for the jack. Its about a 3" section.
larrendeuce
649
Southern NJ
Dec 27, 2007
  • Dec 27, 2007
Are you talking about the rocker panel pinchweld to the floorpan or the subframe?
Alot of jacking on the pinchweld with a regular floor jack will distort and flatten out.
scupking
1,186
Enfield, CT
Dec 27, 2007
  • Dec 27, 2007
The place I used looked like 2 peaces of metal pan caked together.
LaserSVT
3,546
233
Dec 27, 2007
  • Dec 27, 2007
I used to use the sub frame, but last time I was under the car I see the front section of subframe is all jacked up from using the floor jack. So are you guys saying I am supposed to jack it up between the subframe and the mounting points for the rockers?
mustang462002
89
  • Dec 27, 2007
Had the same problem find the frame and use a piece of wood. Cheap jacks tear into it. Just use wood. The bigger 200 bucks one raise the car more evenly so no damage.
  • AeroCoupe
  • Aug 2, 2026
AeroCoupe
N
Vibration after new clutch
  • nipple_looker
  • Sep 20, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 26, 2026
fasterthangas
F
Most ridiculous / dishonest work you have heard a shop recommend?
  • SchwarzStock
  • Jul 19, 2026
  • Off-Topic Hangout
Off-Topic Hangout Jul 20, 2026
SchwarzStock
Tire size question 1986 gt hatchback
  • B0udreaux
  • Jan 12, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jan 17, 2026
B0udreaux
J
Exhaust manifold to Y-pipe nut & stud dimensions?
  • joeybuddy96
  • Jul 7, 2026
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Jul 9, 2026
joeybuddy96
J
