  • SN95 4.6L Mustang Tech
I got bit today
  • Thread starter Thread starter 04JeeTee
  • Start date Start date Jan 27, 2006
04JeeTee
23
Virginia Beach, VA
Jan 27, 2006
  • Jan 27, 2006
So today my buddy showed up in his mustang with a Vortech supercharger and tons of other ****.. he pretty much bought it track ready, but anyways...i got the itch for a supercharger...i know there tons of threads about this...and ive been reading alot...but im kinda partial to the centrifugal(Sp?) style, not sure why...i just like it, but am i able to just bolt on a vortech or novi kit on the stock everything, it owuld only be like a 6-8psi kit...i just wanna buy the kit and put it on. i dont wanna mess with the internals and ****....thanks guys...
01MachGT
104
Marshalltown, IA
Jan 27, 2006
  • Jan 27, 2006
You would have to get a tune regardless. Upgrading your fuel system would be wise. 6-8 psi and you should be fine on stock internals. I'm running 11 psi aftercooled on my stock rotating assembly
04JeeTee
23
Virginia Beach, VA
Jan 27, 2006
  • Jan 27, 2006
oh yeah, thats another thing i dont fully understand, what exactly does a "tune" consist of, if i buy vortech, they say i have to send my ecm(computer right?) to them for them to "play with". im unsure what exactly a tune means...
68
  • Jan 27, 2006
Correct me if I am wrong but a tune is the modification of your fuel delivery system and etc.. Basically modifying your onboard computer (ECU) to better suit the modifications on your car. Doing this will not only keep your car from detonating on you, but maximize the potential of it. You need to purchase a chip or the tuner will throw one in there, depending on where you go.
sgarlic
3,085
Jan 27, 2006
  • Jan 27, 2006
The main point of tune is to adjust your air fuel ratio throughout the RPM range, so that you aren't running too rich and wasting gas/not making enough power, or running too lean and potentially damaging your engine. It also can smooth out rough idle, stalling problems, hesitation problems, shift firmness, shift points, correct speedometer for gear swaps, wheel swaps, MAF changes, injector size changes, the list goes on and on. Dyno tunes cost $$, but definately are worth it if you've got the mods to require it (supercharger, turbo, big cam swap, etc.)
Ernad
celibate sans pants
Apr 2, 2004
Grand Rapids, MI
Jan 27, 2006
  • Jan 27, 2006
get a mongoose kit http://modularpowerhouse.com/index.php?cPath=49_50&osCsid=e93e04fa2b1ccb5cb41f22480996ac89
Dan_Soprano
7,410
54
129
Jacksonville, FL
Jan 27, 2006
  • Jan 27, 2006
a tune changes the stock fuel and spark tables in your vehicles ECU to be better suited and more safe for a supercharged application. The stock table are way to lean and way too much advance spark to be used with a forced induction application. Basically, the ECU uses various inputs such as mass air flow (intake air), Intake air temp, Engine coolant temp, engine load, throttle position, and may others to determine how much fuel and spark to send to the engine.
imblown-ru
247
Roanoke VA
Jan 27, 2006
  • Jan 27, 2006
im not trying to sell anything on the forum but....novi 1000, 7k miles on it. pm me if your ready for one
stangGT97
1,299
Boston area, MA
Jan 27, 2006
  • Jan 27, 2006
haha yeah you are
FI + no tune = boom
slikstevestang
#10
  • Feb 21, 2006
  • #10
answer to all your problems
replace your i.a.c.
DropTopPony
Noob Slayer
2,570
south jersey
Feb 22, 2006
#11
  • Feb 22, 2006
  • #11
slikstevestang said:
replace your i.a.c.
blacknblue2002
159
Va Beach, Va
Feb 22, 2006
#12
  • Feb 22, 2006
  • #12
"im not trying to sell anything on the forum but....novi 1000, 7k miles on it. pm me if your ready for one"
May I ask why you're getting rid of it....I was thinking of getting a Novi...did you have problems?
G
gotchopsticks
315
#13
  • Feb 22, 2006
  • #13
it comes with everything to get your car running fairly well until you can get it on a dyno and have someone tune it. all of the extras cost more if you buy the novi 2000 from paxton and then the parts seperate. mongoose is an awesome deal. when i get $4,200 im going mongoose novi 2000. if ever yuo do decide to go forged internals, you can crank up the boost up to 27lbs, and the s/c its self is rated at 980 hp. imagine that in yur dd...
csledd
Official Ovary Punching Member
1,115
Paducah, KY
Feb 23, 2006
#14
  • Feb 23, 2006
  • #14
www.modularpowerhouse.com
mongoose kit
2001 roush stage 3 - sat for 5 years
  • Brando_05
  • Aug 26, 2025
1996 - 2004 SN95 Mustang -General/Talk- Aug 26, 2025
Brando_05
V6 to V8 Swap info
  • 02_2v_Curtis
  • Jan 11, 2026
1996 - 2004 SN95 Mustang -General/Talk- Oct 7, 2026
2v_johnny
help me understand calibrated maf sensors and injectors
  • stackz
  • Sep 21, 2024
3K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Feb 7, 2026
AeroCoupe
  • D Durden
  • Oct 20, 2025
  • 2 3
4K
N
2003 Mustang GT with Vortech Supercharger.
  • NorCalStang67
  • Jul 16, 2023
2K
1996 - 2004 SN95 Mustang -General/Talk- Jul 16, 2023
NorCalStang67
N
