  • 1994 - 1995 Specific Tech
I hate checking timing....
  • Thread starter Thread starter The Green GT
  • Start date Start date Mar 7, 2007
The Green GT
No 13 year olds are safe around me.
1,269
Louisiana
Mar 7, 2007
  • Mar 7, 2007
Mainly because you cant even get a straight view on the peep hole. I can get the light on it good if I take the resevoir tank out but I can not get a good shot at the hole. So Im left looking at it from the front and guessing what my timing is set at. I just set it and figured I had it set good. It didnt ping like it did before then I got in the HWY and it was pinging.
So how exactly do you see the peep hole?
T
tjh566
608
Northern Va
Mar 7, 2007
  • Mar 7, 2007
stand by the passengerside fender, look down along the belt, theres a small area of a clear shot the the timing pointer. quite easy to check and set once u know where to look also putting white lines on your timing marks helps ALOT.
The Green GT
1,269
Louisiana
Mar 7, 2007
  • Mar 7, 2007
I usually just get some chalk and let the blanacer rub on it for a few rotations.
But I have been meaning to get a white paint marker.
Dan95-5.0
1,110
Manitoba, Canada
Mar 7, 2007
  • Mar 7, 2007
your not supposed to use the hole on the pointer.
thats your problem
The Green GT
1,269
Louisiana
Mar 7, 2007
  • Mar 7, 2007
What is it supposed to line up with then?
T
tjh566
608
Northern Va
Mar 7, 2007
  • Mar 7, 2007
the tip on the pointer, the "point"
The Green GT
1,269
Louisiana
Mar 7, 2007
  • Mar 7, 2007
See mine is round and just has a hole.
Or maybe Im just retarded.
Or maybe its the heat.
Or maybe I just didnt see it.
Im assuming I just didnt see it.
HISSIN50
34
129
Mar 7, 2007
  • Mar 7, 2007
Seriously, Dan and T were right. Use the right-most knife edge.. You might be running more timing advance than you even thought.
Good luck Eric.
The Green GT
1,269
Louisiana
Mar 7, 2007
  • Mar 7, 2007
Yea Ill have to look into that. I didnt set it the first time, so It wasnt off. And it actually doesnt ping as much now, so its better. But ill do it again tomorrow and make sure its right.
1TallMF
955
Montreal
Mar 7, 2007
#10
  • Mar 7, 2007
  • #10
Yeah, its pretty confusing the first time. But once you can see the "knife" edge, and point the light in that general direction, you'll be slapping yourself behind the head for not seeing it the first time. I usually see it through a tiny opening on the left side (as you're looking at it) of the upper rad hose. Its ridiculously hard to see, your eyes need a few seconds to focus on the right spot. Trying not to let the light touch the belt as its whipping around is the next challenge. Good luck.
69clark
731
Ravena, NY
Mar 7, 2007
#11
  • Mar 7, 2007
  • #11
These guys are right with the knife edge info. However, if you think it is hard to see now, You should run a supercharger like me and try to see down in there. I have to pull my supercharger belt and even then it isn't that easy. lol
The Green GT
1,269
Louisiana
Mar 7, 2007
#12
  • Mar 7, 2007
  • #12
Im pretty sure I could take it if I had a S/C
Ill take yours off your hands if you dont like it.
HISSIN50
34
129
Mar 8, 2007
#13
  • Mar 8, 2007
  • #13
If it makes you feel better, I put my timing light into the alternator's external fan and the mech cooling fan while trying to time a GM a week or two ago. I think the service manual says something about using circus performers to view the timing marks, or a special GM tool consisting of a parascope with 5 telescoping mirrors.
:OT: Tom, I keep forgetting to PM you - the wheel is mint and delic!
69clark
731
Ravena, NY
Mar 8, 2007
#14
  • Mar 8, 2007
  • #14
Cool, sounds great JT!
The Green GT
1,269
Louisiana
Mar 8, 2007
#15
  • Mar 8, 2007
  • #15
93 octane seems to have fixed my problem.
gcomfx.com
3,690
Republic, MO
Mar 8, 2007
#16
  • Mar 8, 2007
  • #16
I have to use a shop towel to wrap around the upper radiator hose. Pull it out of the way, then get a bead on it. It also makes a big difference on the light you use. I have a cheapy. It's not very bright and hard to see with. My buddy's dad usually sets mine. His light is much better. He still ******es cause my car is 10 times harder than his fox and he has a super charger on his.
Weber Carburetor tuning help
  • SchwarzStock
  • Jul 6, 2026
1965 - 1973 Classic Mustangs -General/Talk- Jul 19, 2026
SchwarzStock
D
Will 2023 (Non-Handling Pack) Mach 1 Wheels Fit A 2013 Mustang GT OK?
  • dmw_4814
  • Oct 27, 2026
  • 2010 - 2014 Specific Tech
2010 - 2014 Specific Tech Oct 27, 2026
dmw_4814
D
O
8.8 Pinion Nut Leak
  • OX1
  • Jan 3, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jan 5, 2026
OX1
O
F
Fox 1990 Mustang GT 5.0 A9L – Engine suddenly shuts off but immediately restarts when key turned
  • FishermansFriend
  • Aug 9, 2026
General karthief
  • Mindseye007
  • Aug 16, 2026
Mindseye007
