so... I'm not putting this in tech because I don't care for an answer or even know if anyone would give me one (or could)
1 year ago after work I go out to start my car. Nothing. I had to use the key to open the door... I put the booster pack on it and it fires right up, no prob.. no issues after.
today after work I go to start my car. Nothing. I had to use the key to open the door, and once again booster pack time, fires right up, no prob!
but after I shut it off again, the electric fan won't shut off, I unplug it and plug it back in a few times after trying a few things same thing so I take 10 minutes and look for the stupid fan control relay that is supposed to be "behind the coolant overflow and on the rad support". I do'nt see it so I give up and just plug the fan back in and it isn't starting right away. I drive again and there is no issue. its coming on when it's supposed to and turning off when it's supposed to.
* no coolant temp sensor issues, coolant is normal level, snap on scanner is showing that it is working properly according to temp (and obviously no codes present). There is proper 12v on the "purple/green" wire (if I remembered the colors right)*
It's just weird. I don't expect any real answers on this one because it happens once a year... but it just bugs me, cause it's so odd!!!!
