I have been defeated
  • Thread starter Thread starter thegreentaco
  • Start date Start date Feb 5, 2011
First Prev 2 of 2
Black Stampede
1,811
Grand Rapids, MI
Feb 6, 2011
#21
  • Feb 6, 2011
  • #21
opcorn:
Black Stampede
1,811
Grand Rapids, MI
Feb 6, 2011
#22
  • Feb 6, 2011
  • #22
Back to the OP though, do you really have a big square cut out of your hood? Ha, amazing!
thegreentaco
40
Sacramento
Feb 6, 2011
#23
  • Feb 6, 2011
  • #23
Venom351R said:
We have inspections here which means you have to have a legal exhaust system meaning Converters but beyond that its all good. You can run no smog, no EGR and it wont matter
Also changed in 2008 in CA, all catalytic converters must be in their original stock locations and correct numbers MEANING the factory 4 cats that come stock on our beautiful 5.0s must be there, no 2 cat custom 351 exhaust business(which of course I have)...I hate to blame a certain group of people but...its all the many many early 90s civic/prelude/accord owners that chop their springs (thus our headlight heigth law), staight pipe the exhaust (new cat law) and put a coffee can on it (90 decibal noise law), but thats just my opinion nd thats not worth anything.
I hate to get off topic here haha but goin to list out a build that me and my machine shop worked up today, tell me what you guys think
I think this thread should be renamed "CARB build"
$550 100k mile complete motor from junkyard, so i dont have to buy a smog pump/egr/oil pan/distributor/harmonic balancer/flywheel/etc seperately
-and yes Im doing this build on a stock cam for emissions (computer friendly, no tuning), we'll see how far this thing can go
Block work $950
clean
bore + hone w/ plates
surface
line hone
install cam bearings
install pistons on rods
file fit rings
grind crank
balance
assemble short block
Parts (new)
Main bearings $43.46
Rod bearings $44.15
Cam bearings $24.00
Hydraulic roller lifters $150
JE pistons $463.99
Timing set $59.99
Oil pump + shaft $39.25
Trick Flow 170's CARB# D-369-12 $1299
Comp Cams Pro Mag Rockers $298.52
Gangsta Push rods $89.00
Gaskets $164.99
Already have from the 351w: TrickFlow upper intake manifold, BBK 76mm TB, C&L 75mm MAF, all with CARB numbers
Already have from the original 302: Trick Flow lower intake manifold, 19 and 24 lb/hr injectors, MAC shorty headers with 02 bung
So thoughts? Yes this is $4175 build and I know what you guys are gonna say, thats pretty steep for a stock block setup, but it is from scatch and completely smog legal in CA...and Im not doing any of the work except putting intake manifolds on and installing the motor in the car. Plus I have 351w parts to sell off to make up for the cost so its not a total loss.
blksn955.o
3,263
st.louis mo 314
Feb 6, 2011
#24
  • Feb 6, 2011
  • #24
CA has been going BK for some time, going back to at least the early/mid 90s as beyond the social spending their prison system is so large and the population such a drain. Look up the history and development of their criminal/penal system and you will see a lot of states have moved away from following in CA's footsteps due to the large financial strain their laws (ever the downward spiral in themselves) have caused and been causing for a very long time.
blksn955.o
3,263
st.louis mo 314
Feb 6, 2011
#25
  • Feb 6, 2011
  • #25
Block work $950
clean
surface
line hone
file fit rings
grind crank
balance
Parts (new)
Rod bearings $44.15
Cam bearings $24.00
JE pistons $463.99
Timing set $59.99
Gaskets $164.99
Already have from the 351w: TrickFlow upper intake manifold, BBK 75mm TB, C&L 75mm MAF, all with CARB numbers
Already have from the original 302: Trick Flow lower intake manifold, 19 and 24 lb/hr injectors.
Why not just call up CHP and get a shortblock and put your stuff on it? I got my DSS shortblock for around 2,200. CHP was very close in cost but shipping from CA to MO for the CHP and from Chitown IL to St. Louis MO for DSS favored the DSS purchase.
Venom351R
4,548
41
98
MAINE
Feb 6, 2011
#26
  • Feb 6, 2011
  • #26
I disagree w/ everything you said Kurt but Im not going to ruin the OP's thread.
*Clears throat*
See..
Anyway Good luck getting the car running to pass smog on that POS tax happy state.
revhead347
Apparently my ex-husband made that mistake.
20+ Year Stangneter
Jun 14, 2004
9,303
1,649
214
Acworth, GA
Feb 6, 2011
#27
  • Feb 6, 2011
  • #27
Well, I agree to disagree. Sorry for the hijack.
Kurt
thegreentaco
40
Sacramento
Feb 6, 2011
#28
  • Feb 6, 2011
  • #28
just read this beauty
http://www.stangnet.com/mustang-forums/807926-max-power-stock-gt-cam.html
I feel like stock cam builds could be in question in all 49 other states but in CA, its the only option haha, its californias sandbox and i have to play by their rules
I think I will be happy with the power, Im buyin an s/c right after smog too so, good times ahead, Ill keep you guys updated with news and power numbers from this build. Lucky for me my machine shop guy has a dyno in the back of the shop
C
calabria
#29
  • Feb 8, 2011
  • #29
california is a beautiful state but u cant modify your car you get tickets how gay is that michigan is the worst state lol but at least we can lower our cars put hid lights just all out trick it out have no cats **** like that
Mr. Rustypwnz
Advanced Member
Jun 1, 2005
1,761
63
69
indianapolis/ valdosta ga
Feb 8, 2011
#30
  • Feb 8, 2011
  • #30
just register it out of state? thats what I do, done.
2DXTRM
Toronto
Feb 8, 2011
#31
  • Feb 8, 2011
  • #31
CHP has the 347e package. CARB legal.
CHP Street Fighter Short Block - Ford 347 Reverse Dome -14.2cc
Add some CARB legal heads, cam and intake (I know the choices may be slim), but you'll still make decent power and make those Commifornia bastards happy.
Chythar
Recently finished repairing my rear
20+ Year Stangneter
Aug 26, 2004
2,374
140
113
Foothill Ranch, CA
Feb 9, 2011
#32
  • Feb 9, 2011
  • #32
While I agree that California sucks for engine mods, there is plenty you can do within the rules. You just have to follow the rules. For example, I dropped a 1994 Cobra engine in my 1994 V6, and it's all legal - I can get smogged anywhere. I just had to have it inspected and verify all the emissions parts were there. Not that much of a PITA from my POV.
thegreentaco
40
Sacramento
Feb 10, 2011
#33
  • Feb 10, 2011
  • #33
going stock to stock is easy peezy, its the stock to badass which is the difficult part
chaos254
467
NJ
Feb 11, 2011
#34
  • Feb 11, 2011
  • #34
You should be able to get away with an aftermarket catted x-pipe/h-pipe. Smog pump and egr will definitely have to be there. Just make sure all the carb #'s are there for aftermarket parts and you won't have any issues.
Why do you have to pay $25 for a 1 day pass? I have gotten multiple passes from the Davis/Woodland dmv's with no charge at all.
Are you looking to sell any of the parts your taking off? Let me know... I'm about 15 min west of Sac.
Mustang5L5
Mod Dude
Feb 18, 2001
43,380
18,123
224
Massachusetts
Feb 17, 2011
#35
  • Feb 17, 2011
  • #35
Gotta be a way around this.
What did Saleen use for the 351 block for the 94-00 S351? I would bet money it's a truck 351....unless Saleen had a stash of crown vic 351's sitting around for a few years.
What about the 95R? Unique block? OR a truck block?
I wonder if there is a way to get documentation on Saleen using a 351 truck block and then claiming the engine is a 351 Saleen engine???
Venom351R
4,548
41
98
MAINE
Feb 17, 2011
#36
  • Feb 17, 2011
  • #36
Nothing special about the 95R block Mike. Not sure what its actually from but I bet its out of a 351 Lighting.
revhead347
20+ Year Stangneter
Jun 14, 2004
9,303
1,649
214
Acworth, GA
Feb 18, 2011
#37
  • Feb 18, 2011
  • #37
I think it has more to do with year than size. In California, you can't put an engine older than your car in. I now it sounds silly, but they check the year the block was casted. If the block is older than the car, it's a no go item.
Kurt
First Prev 2 of 2
Surging/stalling! problem or tune?
  • djj62478
  • Oct 4, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 14, 2026
KRUISR
Need a clutch, 1982 Capri RS 5.0 owner, am I allowed to participate?
  • scudzuki
  • Apr 4, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Apr 7, 2025
HP woes with Sniper Sytem
  • Stang_1973
  • Mar 10, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Mar 13, 2025
revhead347
Requesting Guidance for 306 motor swap - Fuel? - SD? MAF?
  • So_Flo
  • Jul 26, 2025
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jan 4, 2026
Mcmahst
  • 68_Disgustang
  • Feb 22, 2026
1965 - 1973 Classic Mustangs -General/Talk- Oct 19, 2026
mattcrp1
M
