i have no vacuum!
tomst9
851
Bethlehem Pa
ever since i put my cam in, my brakes haven' worked very well, especially at idle. I threw a vac. guage on today and when the car is fully warmed up i got 8 in.hg of vac. Is that ok. What should it be?. I checked all my vac. lines, but i didn't find any leaks. I know that with the cam i will lose vacuum, but my cam isn' that extreme to lose my power brakes.
thanks
tom
Tom, just a thought, but have you checked the brake booster? if the vac is decent, and you have no assist, then i would look at that possibility.
or run a vac canister as someone mentioned. good luck.
tomst9 said:
how can i check the booster?
thanks for the replies,
tom
i would try to check it like a FPR. put some vac on it with a miti vac, etc, and see if it holds steady or bleeds off. im not sure exactly how a booster works, but that is my best guess on how one could test it.
good luck, Tom.
I just have an E-cam and have always had a low vacuum problem. That coupled with a leak in the break booster (denoted by the "loud vacuum sound") forced me to finally do something about my brakes not working well since the cam install. To solve the problem I replaced the brake booster and installed a vucuum reservoir canister thing and haven't had any problems since. Good luck
