00s281sc368
Great, with 33% drivetrain loss my car almost makes 600HP
I need to call Ford, 5.0 Mag, Hot rod, MM&FF, Road & Track, Car & Driver ... and everybody else for the amazing news !
i dunno if you realize the difference between a dynojet and a mustang dyno00s281sc368 said:Great, with 33% drivetrain loss my car almost makes 600HP
I need to call Ford, 5.0 Mag, Hot rod, MM&FF, Road & Track, Car & Driver ... and everybody else for the amazing news !![]()
the only reason i did a pull without it was because i didn't happen to have my stock one there. & i just put those number in there, both corrected & non, was for fun. Dear God people lighten up. i didnt go out & try to disprove anyone, it was a spur of the moment thing, that i thought had some interesting results. if it rubbed you the wrong one cause you may happen to have one under your hood, oh well. i'll be sure to get another dyno before i put on my l/t's & mid pipe, with back to back runs
Ruckus46Gt said:doesn't your computer have to adjust its settings for the k&n?
where do these people come from. You can roughly use that 30% if your talking your going to use the rwhp number from the mustang dyno. In other words if you put down say 200 at the wheel then take that 200 and multiply it by .3 then add that to the 200 to get your flywheel hp.
good job. just outta let you know it IS scientific, BUT, he just wasnt organized well.bennyjammin said:Sounds like you're on a mission to prove the majority wrong, so let me add a few points:
-You're "experiment" is completely unscientific.
You made dyno runs on separate days, months apart- although you may think the conditions were the same how do you know? Do you have accurate measurements for barometric pressure, temperature, and humidity for both runs?
-You're dumb enough to run your car without an air filter... and then point out to us that it made more power without any filter at all- Duh!!!!
-You attribute 2-3 tenths at the track to switching to the stock filter. i don't think so
-Did you consider that your k&n possibly got dirty between October and now, causing the horsepower loss?
- I think when the guy said to add 33%, he didn't mean to add it to the corrected numbers- your stock mustang is not putting out 296hp to the flywheel
I don't think anyone here thinks that a K&N is a world beater- but countless dyno tests have shown that it does give a slight advantage (2-3hp) and outflows the stock paper filter.
