I installed my home made Subframe connecters.
  • Thread starter Thread starter 5.0Droptop
  • Start date Start date Feb 7, 2008
  • 3
1 of 3 Next Last
5.0Droptop
...all those nights we shared, and you're a dude??
Special Agent Mukity-Muck Whats in Charge Round Here
May 15, 2002
1,785
1,130
233
Indiana
Feb 7, 2008
  • Feb 7, 2008
I had made a post about making my own SFC.
I bought some 1x1x48" material from my local Tractor supply. 2 pcs $20.00
The car is nice and stiff now.
It worked out very well. I used the full length 48" tube. It started Just behind the tranny cross member bracketry and ended right at the end of the rear subframe before it curves up.
I used my little Lincoln flux core mig welder and did the install in my garage.
I know many people say you should not install them on jackstands.
However:
I have spoken with a close friend of the family about this.
Danny has built more race cars than I can account for. I am talkin 1200 hp + street rods and track racers.
He assured me that it would be fine as long as I supported the car on 2 solid frame points.
Since then I have welded in several sets of mustang SFC's on jack stands in my garage and I also did 1 trans-am.
None of the cars have ever sat funny nor have the owners complained.
This time I even measured before and after and the car sat exactly the same.
With that being said heres some pics.
ryan218
In just 10 years, I'll be old enough to drive!!!!
Dec 28, 2005
columbus ohio
Feb 7, 2008
  • Feb 7, 2008
cool...throw some paint on it now or some por-15 so it dont start to rust.
5.0Droptop
May 15, 2002
1,785
1,130
233
Indiana
Feb 7, 2008
  • Feb 7, 2008
I primered em. I am going to paint them white.
ryan218
Dec 28, 2005
columbus ohio
Feb 7, 2008
  • Feb 7, 2008
cool...get at it.
5.0Droptop
May 15, 2002
1,785
1,130
233
Indiana
Feb 7, 2008
  • Feb 7, 2008
it can wait I am busy posting plate suggestions in your thread.
ryan218
Dec 28, 2005
columbus ohio
Feb 7, 2008
  • Feb 7, 2008
learn how to mutli task noob
5.0Droptop
May 15, 2002
1,785
1,130
233
Indiana
Feb 7, 2008
  • Feb 7, 2008
i need paint. I dont feel like going to get it...
ryan218
Dec 28, 2005
columbus ohio
Feb 7, 2008
  • Feb 7, 2008
gives you a reason to leave the house...and drive the 5.0
why not!
Seanmay1
47
Conyers, GA
Feb 7, 2008
  • Feb 7, 2008
thats a good idea, and a lot cheaper than buying SFC i will probably do this, how much did the tubing cost you?
5.0Droptop
May 15, 2002
1,785
1,130
233
Indiana
Feb 7, 2008
#10
  • Feb 7, 2008
  • #10
bloopbloob
578
Alberta
Feb 7, 2008
#11
  • Feb 7, 2008
  • #11
just curious.... any reason you welded them right out instead of just stitch?
5.0Droptop
May 15, 2002
1,785
1,130
233
Indiana
Feb 7, 2008
#12
  • Feb 7, 2008
  • #12
I figgured the more I welded the less chance there would be for it to break the weld or rip away from the subframe.
Its personal preferance. The passinger side is stiched more than solid due to the shape of the subframe and the dents it had from jacks.
bloopbloob
578
Alberta
Feb 7, 2008
#13
  • Feb 7, 2008
  • #13
not hackin on you, but i just don't like throwing a lot of heat into thin metal. a couple good stitches should do the same job as a solid weld.... but with much less heat to warp things.
5.0Droptop
May 15, 2002
1,785
1,130
233
Indiana
Feb 7, 2008
#14
  • Feb 7, 2008
  • #14
Ive been a welder fabricater for 20 yrs. It is possible to lay a long weld and not over heat it.
You can weld an inch or 2 and jump to another place. weld there and jump to another place etc etc.
The welder I use is a very small one and dosent make alot of heat compared to higher amperage ones.
I didnt burn through in one place,so it is all good.
Like you said. It coul dbe stiched and hold well.
I just prefer to connect the SFC to as much metal as possible.
Darkwriter77
Resident Ranting Negative Nancy
5 Year Member
Jul 1, 2005
314
281
134
Apache Junction, AZ
Feb 7, 2008
#15
  • Feb 7, 2008
  • #15
I wantses some cheap SFC's, too.
5.0Droptop
May 15, 2002
1,785
1,130
233
Indiana
Feb 7, 2008
#16
  • Feb 7, 2008
  • #16
Come on over . Ill hook you up.
ryan218
Dec 28, 2005
columbus ohio
Feb 7, 2008
#17
  • Feb 7, 2008
  • #17
you just have to space the welds apart some and keep moving around and not stay in the same area.
5.0Droptop
May 15, 2002
1,785
1,130
233
Indiana
Feb 7, 2008
#18
  • Feb 7, 2008
  • #18
bloopbloob is right it can be stitch welded also. I just prefer to solid weld as much of it as possible.
When I put floor pans in a 66 mustang and a 70 mach1 for my buddy I welded all the way around. I would stitch about 2 inches and go weld somewhere else etc etc etc.
When it was done it was strong. and it didnt need to be seam sealed.
Some people consider it overkill, I just prefer to do it the way I feel is right.
ryan218
Dec 28, 2005
columbus ohio
Feb 7, 2008
#19
  • Feb 7, 2008
  • #19
same...do it the right way the first time.
foxmustangman
196
Idaho
Feb 7, 2008
#20
  • Feb 7, 2008
  • #20
*writes welding notes down in notebook*
  • 3
1 of 3 Next Last
  • B0udreaux
  • Jul 14, 2026
AeroCoupe
Drivetrain 83’ Glx convertible C5 Trans help!
  • JacksonJared2113
  • Dec 25, 2025
Fox 5.0 Mustang Tech Dec 26, 2025
JacksonJared2113
E
Finished my Fox Hydroboost Install - Tips
  • Engineer Duane
  • Apr 9, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- May 5, 2025
Engineer Duane
E
Mid lenght sub frame connectors (straight)
  • Dontknowchit
  • Apr 13, 2024
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Apr 14, 2024
bird_dog0347
J
  • JRC99
  • Apr 19, 2025
JRC99
J
