I was replacing my engine oil dip stick tube and it broke off on the block. I tried to pry it up but broke off even with the hole. So I took a sharp punch and bent in one side so I could get a hold of it with some long nose plyers. Did not go so well. The broke off part fell into the oil pan. My question is- Can I drive the Mustang to the shop to have this taken care of? I only have a gravel carport and do not feel like laying in the gravel for an hour or so taking the parts off in order to get the pan off. I also have a bad back. Should I drain the oil and replace it first? What is the chanch of that part of the tube gittint into the block? I use to change my own oil years ago but now there are so many rules and I do not get around as good as I use to being 67. I am in no means a mechanic so their job is safe with me. Thanks
By the way. My engine is a 289 in a 65 Mustang.
